Battery Dead + Trunk Wont Open
Old 04-03-2016, 11:16 AM
  #51
Finelli714@gmail.com's Avatar
Originally Posted by Kesha Michaels
Just so you know, there is a release for the trunk. Lower down your back seat and crawl to the back (hopefully you are not scared of small spaces) . You will see a white trunk release to pull. I have had this problem with not being able to unlock my trunk and needing to jump my car. Sounds ridiculous but... sadly is true.
How did your lower your seat to get into the trunk??
Old 04-03-2016, 11:38 AM
  #52
EmperorJJ1's Avatar
on the fuse box is a positive post. put the jumper cables on that and a ground (normally strut tower) and jump from there
Old 04-03-2016, 04:37 PM
  #53
double clutch's Avatar
The latch release for the seat is in the trunk lol.
Old 05-25-2016, 10:28 PM
  #54
carlgodbey's Avatar
chev colbolt ,,whin trunk won,t unlock with dead battery ,,put the key in trunk lock
Originally Posted by wudman
2006 Chevy Cobalt
The battery is dead, the battery is in the trunk, and the trunk wont open. Not even with the key.
Is there a trunk release leaver on the inside of the car somewhere?
Or, is there a way to jump the car under the hood? If so, where are the terminals and what do they look like?
Any other options would be appreciated.
Thanks in advance
Old 05-25-2016, 10:36 PM
  #55
carlgodbey's Avatar
put the key in trunk and peck on key to make it go in futher it will unlock trunk ,whin battery is dead ,,also red post under hood driver side ,charge ,,red on post black on strut nut ,will let u get key out of ignition and charge ur battery to ,,also jump start from there carl
Sl0wbaltSS
11-21-2018 11:11 PM
10-13-2015 09:32 PM
grampss
09-27-2015 08:51 PM
c_m_shooter
09-27-2015 04:40 PM
soaxin
09-26-2015 08:41 PM
Quick Reply: Battery Dead + Trunk Wont Open
