Cobalt Audio Pinouts
Old Jun 5, 2005 | 06:35 PM
zinner's Avatar
Moderator Alumni
Originally Posted by Maven
Amplifier and Radio pinouts, circuit ID's, color codes:
Audio Amp. Connector1
Connector Part Information
• OEM: 12110088
• 24-Way F Micro-Pack 100 Series (GY)
Pin
Wire Color
Circuit No.
Function
A1
L-GN/BK
1794
Left/Rear Subwoofer Speaker (-)
A2
D-BU/WH
346
Left/Rear Subwoofer Speaker (+)
A3
L-BU/BK
115
Right Rear Speaker Signal (-)
A4
D-BU
46
Right Rear Speaker (+)
A5
BN
199
Left Rear Speaker (+)
A6
YE/BK
116
Left Rear Speaker Signal (-)
A7
D-BU
546
Right Rear Low Level Audio Signal
A8
BN/WH
599
Left Rear Low Level Audio Signal
A9
TN
1946
Right Rear Low Level Audio (-)
A10
BN
1999
Left Rear Low Level Audio (-)
A11
D-GN
117
Right Front Speaker Signal (-) (1)
A12
L-GN
200
Right Front Speaker (+) (1)
B1
L-BU/BK
315
Right Subwoofer Speaker (-)
B2
D-GN
1795
Right Subwoofer Speaker (+)
B3
D-GN
1947
Left Front Low Level Audio (-)
B4
L-GN
1948
Right Front Low Level Audio (-)
B5
TN
511
Left Front Low Level Audio Signal
B6
L-GN/WH
512
Right Front Low Level Audio Signal
B7-B10
Not Used
B11
GY
118
Left Front Speaker Signal (-) (1)
B12
TN
201
Left Front Speaker (+) (1)
Audio Amplifier Connector2 (UQ3)
• OEM: 12110626
• 8-Way F Metri-Pack 280 Series (L-GY)
Pin
Wire Color
Circuit No.
Function
A
BK/WH
1051
Signal Ground
B
BK/WH
1051
Signal Ground
C
Not Used
D
L-GN
1011
Remote Radio Control Signal
E
PK
314
Radio On Signal
F
Not Used
G
RD/WH
640
Battery Positive Voltage
H
RD/WH
640
Radio C1
• OEM: 12110206
• Service: See Catalog
• 24-Way F Micro-Pack 100 Series (L-BU)
Pin
Wire Color
Circuit No.
Function
A1
GY
118
Left Front Speaker Signal (-) (1) (U1C)
A1
D-GN
1947
Left Front Low Level Audio (-) (US8)
A2
TN
201
Left Front Speaker (+) (1) (U1C)
A2
TN
511
Left Front Low Level Audio Signal (US8)
A3
L-BU
115
Right Rear Speaker Signal (-) (U1C)
A3
TN
1946
Right Rear Low Level Audio (-) (US8)
A4
D-BU
46
Right Rear Speaker (+) (U1C)
A4
D-BU
546
Right Rear Low Level Audio Signal (US8)
A5
BN
199
Left Rear Speaker (+) (U1C)
A5
BN/WH
599
Left Rear Low Level Audio Signal (US8)
A6
YE
116
Left Rear Speaker Signal (-) (U1C)
A6
BN
1999
Left Rear Low Level Audio (-) (US8)
A7
L-GN
200
Right Front Speaker (+) (1) (U1C)
A7
L-GN/WH
512
Right Front Low Level Audio Signal (US8)
A8
D-GN
117
Right Front Speaker Signal (-) (1) (U1C)
A8
L-GN
1948
Right Front Low Level Audio (-) (US8)
A9
D-BU
1796
Steering Column Radio Control Signal (UK3)
A10
WH/BK
644
10-Volt Reference (US8)
A11
Not Used
A12
BK/WH
1051
Signal Ground
B1
RD/WH
1140
B2
Not Used
B3
L-GN
1011
Remote Radio Control Signal (US8)
B4-B5
Not Used
B6
PK
314
Radio On Signal
B7-B8
Not Used
B9
D-GN
5060
Low Speed GMLAN Serial Data
B10-B12
Not Used
Radio Connector2
• OEM: 12064799
• 12-Way F Micro-Pack 100 Series (BK)
Pin
Wire Color
Circuit No.
Function
A-G
Not Used
H
D-GN/WH
368
Right Audio Signal (+)
J
BN/WH
367
Left Audio Signal (+)
K
TN/WH
372
Audio Common
L
OG/BK
2061
Cellular telephone voice Low Reference (UE1)
M
PK/BK
2062
Cellular Telephone Voice Signal (UE1)
relevant RPO descriptions:
UK3
Control, Steering Wheel, Accessory
UN0
Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR
UQ3
Speaker System, Performance Enhanced Audio
UQ4
Speaker System, 4, Base
US8
Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
U1C
Radio, AM/FM Stereo, Seek/Scan, CD, Clock, ETR
U2K
Digital Audio System S-Band
UE1
Communication System, Vehicle, G.P.S. 1
the radio DOES communicate on the Lowspeed GM-LAN line, it recieves VIN information for TheftLok, illumination dimming inputs, and signal for speed compensated volume.
Some audio functions are available using the steering wheel controls. The steering wheel controls are actually a resistor network which consists of multiple momentary contact switches and a series of resistors. The switches and resistor network is arranged so that each switch has a different resistance value. When a switch is pressed, a voltage drop occurs in the resistor network which produces a specific voltage value unique to the switch selected. These specific voltage values allow the radio to identify which switch has been pressed. The radio responds just as if the corresponding radio front panel button had been pressed.When the radio is ON, the radio supplies approximately 10 volts to the switches on the 10-volt reference circuit. The specific voltage signal from the switch is returned to the radio on the steering wheel controls signal circuit.This may inhibit the use of the redundant control with an aftermarket head unit.
(Gm Service Information 2005 Chevrolet Cobalt)
Some of you may have been aware of this information, many of you may not have, hope it helps any who need it.
__________________
ASE certified Master Technician
ASE certified Advance Engine Performance Specialist
General Motors certified Technician
General Motors Mark of Excellence Platinum ranked(engine repair)
I figured this should be a sticky
Turbo6
Sep 24, 2015 04:15 PM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
