Zzp Ftl
Old Mar 14, 2008 | 07:00 PM
Black SS 07's Avatar
Angry Zzp Ftl
1500 miles... 2 sets of gaskets... 2 sets of upper DP bolts.. and now this...
ive never had a problem with ZZP until now.. anyone else have this problem?
Old Mar 14, 2008 | 07:02 PM
BriantheLion26's Avatar
I have a lot more than 1500 miles on my DP from them and never had a problem. Hopefully you can get it figured out.
Jimmys2007CobaltSS/C's Avatar
nope but i did go through new bolts cause the pop out and gave me an exhaust leak
Old Mar 14, 2008 | 07:03 PM
redwingsfan91086's Avatar
That same damn thing happened to my magnaflow exhaust, but it did last a good 10k before it did it.
Old Mar 14, 2008 | 07:11 PM
probably should add.... yes.... that is a BOLT ON DP.. lol the other part is still on the header
Old Mar 14, 2008 | 07:14 PM
Mr_Slobalt's Avatar
I've never really heard anything good out of ZZP's exhaust stuff. The Grand Prix/Regal downpipes they used to sell had bad flex pipes that would actually restrict the exhaust after time. Turns out the "weaves" would come apart on the inside.
Zooomer is a stand up guy. I'm sure if you talk to him he'll work something out for you.
Old Mar 14, 2008 | 07:24 PM
Yeah i know. thats why i'm not too worried. ive been a ZZP customer since early 2006.. spent a lot of money with them too. between the GP and SS im sure im over 5k spent with them. lol
for now i just have to run open header... oh well lol
Old Mar 14, 2008 | 10:09 PM
Mr_Slobalt's Avatar
AH, I didn't notice your sig
I've been a customer since '05 probably
Old Mar 14, 2008 | 10:15 PM
Z Speed's Avatar
had there 3 inch catless dp for 17k at least and never a problem
Old Mar 14, 2008 | 10:16 PM
RollOver360's Avatar
Wow that sucks. I just installed my ZZP midlength header/ dp combo and in less then 24 hours (only 20-30 miles of driving) 1 of the "Grade 9" Bolts snapped. I think it was a combo between 1 the "Grade 9" bolts are a cheap chinese knock off and 2 the bolts are 3/8" and the wholes in the flanges are 7/16" which has a lot of play and could cause the bolts to break. So I upgraded to some 7/16-14 X 2" Grade 8 Yellow Zinc plated bolts with 7/16 Hi-alloy lock washer, 7/16 SAE Thru-hard washers, and some top lock flange nuts. Im hoping the setup lasts longer then the stock set up. lol. Also I have a weird ass noise that I cant figure out. Good luck man, let us know how u make out.
late
Old Mar 14, 2008 | 10:44 PM
Mr_Slobalt's Avatar
this is part of the reason why my exhaust is staying stock...it's loud enough for me
Old Mar 14, 2008 | 10:46 PM
Raven SS's Avatar
looks like ur running a little rich...blame ur tuner
Old Mar 14, 2008 | 11:01 PM
lol header and DP isnt for noise... im keeping the stock catback for that reason.. then just running a cutout when i race.
its just the base tune from zzp...
no other tuning has been done..
Old Mar 14, 2008 | 11:03 PM
Raven SS's Avatar
out the box tunes are alright..but there too general..not dialed in for ur car..i recommend getting retuned
Old Mar 14, 2008 | 11:15 PM
Mr_Slobalt's Avatar
Oh I know. If I replace part of the exhaust, the rest is being replaced along with it. It's just how I am.
Old Mar 15, 2008 | 12:33 AM
saunders1986's Avatar
ouch
Old Mar 15, 2008 | 11:06 AM
I had that same tune, and lets just say I had a AFR in the 13's and 30 degrees of timing. I would suggest going and gettin a REAL tune ASAP.
later
Old Mar 15, 2008 | 11:09 AM
cobalt_driver's Avatar
later
ouch...
ur dp is hella carbed.
Old Mar 18, 2008 | 11:54 AM
forced_induction's Avatar
damn im bout to put mine on tomorrow, hope i dont have the same problems
Old Mar 18, 2008 | 11:58 AM
Area47's Avatar
Rent me! per hour
they used the wrong type of flex pipe.
Old Mar 18, 2008 | 12:00 PM
sick06cobalt's Avatar
man... ive never had a problem with mine but i do need a new cat... mines fried...
Old Mar 18, 2008 | 12:07 PM
I have had a ZZP 3 inch hi flow cat pipe for over a year with no problems (with that flex pipe type). It doesn't look like that pipe in the 1st post. What kind of pipe is that?
Old Mar 18, 2008 | 12:10 PM
freakta's Avatar
i have major problems with the zzp setup also. my header doesnt mate up to my downpipe correctly and i had to make my own gaskets that were thick to close the gap. also my bolts were no good, so i got some better ones and some better washers to make it fit. then i found my cat was no good, the 3 inch high flow. we dynoed my car after i put everything on and broke it in correctly and i lost hp. so i cut the damn thing out and it was solid black inside (yes i have a great tune) and if i turn it around there was stuff rolling inside it. so i too have had no luck with there products.
Old Mar 18, 2008 | 12:20 PM
SSMOKEM's Avatar
happened to me as well, after a month of driving.
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
