wtf is this noise!
Old Nov 11, 2008 | 04:46 PM
Preston's Avatar
wtf is this noise!
ok
EVERYTIME i go in reverse i get this screeching sound..
like something is rubbing against something
and when i go forward til about ehh 15ish
but i notice it mostly when in reverse
any idea?
im debating on taking it in but want an idea of what it is
Old Nov 11, 2008 | 04:48 PM
Brenticus's Avatar
are you a manual?
Old Nov 11, 2008 | 04:53 PM
Preston's Avatar
oh yeah
hah yes i am
2.2 if that means anything 2007
Old Nov 11, 2008 | 04:56 PM
Brenticus's Avatar
reverse in a 2.2 manual always has a toy car sound to it. is that what you're hearing?
Old Nov 11, 2008 | 04:57 PM
BowTieTillIdie's Avatar
I would say you need a belt or an alternator / powersteering or something man LOL not sure without hearing the noise and being their .... have some one else replicate the noise and you stand out side to figure out where its comming from
Old Nov 11, 2008 | 10:56 PM
Preston's Avatar
maybe ill record it
its like a creaking sound..ive never heard it before..its wierd
Old Nov 12, 2008 | 12:27 AM
sscharged112's Avatar
just might be the piece of metal on the break pad that tells you when the pads are low. Sometimes they get bent and rub against the rotor. You said that you can hear it in both reverse and forward...to about 15 mph.....that is what i would guess it to be...
Old Nov 12, 2008 | 08:03 AM
Vetteman-sssc's Avatar
Could be a strut or shock.
Just add it to the list of problems these cobalt have.
Old Nov 14, 2008 | 06:55 AM
rnjmur's Avatar
1. If it were a belt he should hear it all the time, not just mainly when in reverse.
2. The Cobalt does not have power steering.
I would guess it is the brakes, probably the rear brakes. My car does the same thing but mostly happens when I initially move the car in reverse. I think it has to do with the rear brakes not releasing quick enough when the parking brake has been taken off. My theory is that you park the car and apply the parking brake while the brakes are still hot. This causes the brakes to "stick" to the rotor (or drum if you have drum brakes). When you take the parking brake off and start moving the pads have to "unstick" and retract causing a bit of drag on the rotor or drum hence the noise you hear.
Old Nov 14, 2008 | 06:57 AM
steddy2112's Avatar
We have power steering, it's electric
Old Nov 15, 2008 | 03:10 PM
rnjmur's Avatar
Its not power steering. It is electric assist steering. The two terms are not interchangeable.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
