throttle body
Old Dec 12, 2008 | 01:23 PM
rockstar014's Avatar
throttle body
whats the best throttle body u can buy that will add most??
Old Dec 12, 2008 | 01:37 PM
NarutoDF's Avatar
not sure if you can get one for the 2.4L i havt found one yet. I know my friend got one but he bought the 2.4L throttle body for his 2.2L. I think the 2.4L has the largest out of the three. I could be wrong, the 2.0 may have the better one.
Old Dec 12, 2008 | 01:43 PM
oic..
Old Dec 12, 2008 | 02:12 PM
pat_07ss's Avatar
on an NA 2.4, that's a good question
there's a bunch of threads about this already; still no one has tried it on an NA SS
Ours is 68mm (aoubt 2.7 inches ID), so there's been debates saying that larger could be an overkill and show no gains
Old Dec 12, 2008 | 06:18 PM
slowswap's Avatar
You can adapt an LSJ throttle body if you want, but you will lose a lot down low. I don't think the gains would be worth it.
Old Dec 12, 2008 | 06:22 PM
pat_07ss's Avatar
a 2.4 TB is almost the same as an LSJ's, it's not worth it for the amount of work and figuring out which wire goes where
(they don't have the same colors...)
Old Dec 12, 2008 | 06:23 PM
slowswap's Avatar
It's already been figured out in Beck's thread.
Old Dec 12, 2008 | 06:25 PM
pat_07ss's Avatar
true i remember that
Old Dec 13, 2008 | 12:38 AM
well i jus dont know...
Old Dec 20, 2008 | 12:08 AM
NarutoDF's Avatar
what about on the 2.2? a friend of mine that slowswap knows apparently has the 2.4L throttle body on his 2.2 is there any noticable gain there or is it still a small difference?
Old Dec 20, 2008 | 12:15 AM
slowswap's Avatar
It's a more noticeable gain because the 2.4 throttle body matches his 2.4 intake manifold. The 2.2 throttle body on a 2.4 manifold would be to small to fill the plenum fast enough. To large of a throttle body is also bad. It's all relative to the design of the intake manifold, as is the length of a cold air intake.
Old Dec 20, 2008 | 07:50 AM
redssna's Avatar
He also did complain though that he lost a lot of his low end torque because of the 2.4 intake manifold and throttle body. Its definitely more beneficial in the upper rpms.
Old Dec 20, 2008 | 11:06 AM
slowswap's Avatar
That's because the plenum on the intake manifold is to big.
Old Dec 20, 2008 | 12:52 PM
redssna's Avatar
Yup I know. I think he was thinking about switching back.
Old Dec 20, 2008 | 01:32 PM
Dmoney8187's Avatar
The 2.4 throttle body is not the problem, it actually helped gain back some low end. The 2.4 intake manifold is what really brought the low end power down. I'm definitly happy with the overall high end gain
Old Dec 23, 2008 | 09:47 PM
NarutoDF's Avatar
yeah mine really kicks in at like 4000RPM. And about half into 2nd gear or it picks up, but ultimately i think 3rd gear is my best gear at the moment.
Old Feb 13, 2009 | 11:45 AM
pat_07ss's Avatar
so ZZP managed to get about 1whp with an LSJ throttle body
considering that there's not a big difference in size, i don't think that the low end loss in power would be much noticeable
it's much more noticeable if you add a 3'' intake IMO, but what u gain in the high end is much worth it
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
