how to paint door interior pieces.
Old Apr 8, 2009 | 02:48 PM
05LSCobalt's Avatar
Alright so i made a how to in the hot to thing and never got apporved, now a few ppl had been asking me how i done it. so here is my wright up.
Tools: Flat head screw driver, Phillips head screw driver, Window crank remover(if you have manual windows) your color of Dupli-color vinyl spray. hot glue gun, razor blade.
1. REMOVE COVERS. take the flat head a pry easily to pop up the covers that cover the philips screws.
2. remove window cranks or switches/bezel. okay so i figured i would do this for the manual guys. get a window crank removal tool and a parts store and stick it between the crank and the plastic washer, turn the crank untill you see the clip come off. pull the crank off and sit down.
3. now take your fingers and go around the edges and pull the panel off the door. might take some effort. then you will be greet by this.
4. once the door panel is off discontect everything so you can move the panel around. now, take the razor blade and cut the plastic rivets that hold the inster to the panel. and then give it a little push. (not to hard, you can easily damgage the insert.
5. now that you have it off this is what it should look like.
6. time to paint/dye. make sure its very clean with no oil spots or hair, ETC, lay down 1 light coat to start to change the color. let dry. then lay down a 2nd medium coat, let dry, then another medium coat, then a final light coat. this is what is should look like when done.
Hope this helps everyone and hope it can get moved to the how to section.
Old Apr 8, 2009 | 04:37 PM
SteveORyan's Avatar
thats nice man, i want that stuff, how much man
Old Apr 9, 2009 | 02:22 PM
SteveORyan's Avatar
can i see finished wrk with it in?
Old Apr 30, 2009 | 04:31 PM
bigdogstokes16's Avatar
is it possible to take the window crank off without using the window tool? or breaking it?
Old Apr 30, 2009 | 04:34 PM
ZeeBee's Avatar
yep you use a cloth, hold it like floss and pull, the clip will then come out
Old Apr 30, 2009 | 04:55 PM
thanks
lobalt's Avatar
Woo, I found one of my next projects!
Old Apr 30, 2009 | 05:01 PM
cobalt123's Avatar
very nice
Old Apr 30, 2009 | 05:20 PM
biniecki's Avatar
Nice write-up. However for painting the plastic I found krylon fusion paint works the best. For the insert its best to just recover it. The duplicolor dye lasts a little while but in my experience it faded very quickly.
Old Apr 30, 2009 | 06:17 PM
05LSCobalt's Avatar
thanks and yeah mine looks good so far. but ill probably recover them in leather. and probably just dye the headliner.
Old May 2, 2010 | 04:17 PM
mrgrinch's Avatar
Only question i have about this whole thing, is when removeing the arm rest pieces, you just cut the plastic weld things off?? that's what it looks like to me, just wanted to make sure, about to go get some fabric right now and start on this project and another one w/ my door panels.
Old May 2, 2010 | 04:19 PM
09bluebalt's Avatar
holy huge pictures batman!!!!!! looks good though! probably a good summer project for me
Old May 2, 2010 | 08:28 PM
Burninrubber's Avatar
how to you put it back together.
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
Sep 26, 2015 06:44 PM
riceburner
Sep 26, 2015 12:57 AM
