2.4 to 2.2 swap help me
Old Jun 15, 2009 | 01:39 PM
gotboost's Avatar
Hey guys i can get a 2.4 out of a HHR for cheap. I have a 09 2.2 LS is this just a swap in and out or is there a lot of work to be done?
Old Jun 15, 2009 | 01:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
trade the car in and buy a 08 sport. it will be cheaper
MP Cobalt's Avatar
to much work. keep the 2.2 and build it.
Old Jun 15, 2009 | 01:48 PM
exiged's Avatar
x3 waaay too much for like 20 hp tops.
Old Jun 15, 2009 | 01:54 PM
xCobalt05x's Avatar
he must have saw ZZP's thread about them getting their 2.4 automatic balt into the 11's w/ drag slicks, turbo kit, 78lb valve springs, ZZP downpipe and exhaust, and rear spring blockers.
Old Jun 15, 2009 | 01:55 PM
riko540's Avatar
lol you might want to change your title because it sounds like you already have the 2.4L and swapping to the 2.2L As far as swapping out the engine its possible but very costly......for starters you practically have to rewire the entire car because the wiring harnesses are not the same or so I've read.
Old Jun 15, 2009 | 02:30 PM
gotboost's Avatar
thanks just thought the 2.4 was a bigger version of the 2.2. I have a freind how wrecked his hhr and was going to give me the motor for $250
Old Jun 15, 2009 | 02:54 PM
Blue_Balt's Avatar
Well the LAP is a slightly smaller version of the LE5.
Old Jun 16, 2009 | 08:23 AM
Sindri907's Avatar
Just to muddy the waters a little bit...
Couldn't an FE5 be almost a direct drop in to an LAP car? The LAP shares the FE5 intake manifold, cylinder head, and both have the VVT and Coil-On-Plug ignition. Seems to me that it *could* work.
That being said, it may only be $250 for the motor, but theres going to be lots of other expenses and it will take a lot of time. For what you'll end up putting in it, there's cheaper and easier ways to make 20hp.
Old Jun 16, 2009 | 08:35 AM
xCobalt05x's Avatar
he would need the engine harness and the computer for the FE5... other then that yeah would work... i would say from start to finish a month long project.
Old Jun 16, 2009 | 12:23 PM
riko540's Avatar
I think you mean the LE5, the FE5 is the suspension setup that is on the SS/SC and TC
Old Jun 16, 2009 | 12:25 PM
umrdyldo's Avatar
Buy it for $250, then sell it for more.
Old Jun 17, 2009 | 09:06 AM
gotboost's Avatar
i wan to do a bottom end swap go from a 2.2 to a 2.4 that's all
Old Jun 21, 2009 | 07:15 PM
Jn2's Avatar
Jn2
wont work, way more work than what its worth, like it has been mentioned, there is a better way to make those ponies, and a swap is just not a good way to do it, the $$:hp ratio is way off, the best bang for your buck would be to get the car tuned with those 250
Old Jun 25, 2009 | 03:02 PM
xxxxsh4d0wxxxx's Avatar
Might as well just run a snail.
Old Jun 29, 2009 | 08:41 AM
gotboost's Avatar
i thinking of turboing my ls instead of buying another sti. If i turbo it i will go get a gt35 or gt40 r if the 2.2 can handle it. Kind of new to the ecotec motor had a ss/sc when it came out but chevy bougth it back because of problems
ThoR294
Oct 4, 2015 08:44 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 26, 2015 06:44 PM
