where can i buy brand new stage 2 kit?
Old Jul 26, 2009 | 10:20 AM
mensurSS's Avatar
GM discontinued the stage 2 kit and i looked on ebay the guy said they are on backorder with no ETA. does anyone know any website where i could get the kit for a good price?
Old Jul 26, 2009 | 10:26 AM
ecotecturbo's Avatar
right here
http://www.crateenginedepot.com/stor...P1540C196.aspx
Old Jul 26, 2009 | 10:35 AM
mensurSS's Avatar
thanx a lot, i just need that kit right, i dont need to buy a stage 1 kit to?
Old Jul 26, 2009 | 10:40 AM
EatonTVS07's Avatar
nope stage 2 will come with all you need
mensurSS's Avatar
perfect thanx a lot guys, cant wait!
Old Jul 26, 2009 | 10:42 AM
EatonTVS07's Avatar
no prob. let me ask, do you still have your warranty? I only ask cause if you dont, the OTT stage 1 is much better then the GM stage 2
Old Jul 26, 2009 | 10:44 AM
mensurSS's Avatar
no i dont but doesnt the stage 2 give a more power?
Old Jul 26, 2009 | 10:45 AM
EatonTVS07's Avatar
no, honestly i would go with the OTT stage 1, cheaper and comes with a better tune, bigger injectors and a 2.8 pulley. that will leave you some money to get some cooling mods.
Old Jul 26, 2009 | 10:48 AM
mensurSS's Avatar
i looked at the stage 1 its just comes with injectors?
Old Jul 26, 2009 | 10:50 AM
I would go with the gm stage 2. It is a safer setup unless you have cooling mods.
Old Jul 26, 2009 | 10:51 AM
Perfect.disguise's Avatar
Yep, the GM kit only has 42lb injectors that are maxed out if you pulley down to a 2.9. Think of it this way GM stage drops down .29 in pulley size..OTTP drops down .26 lower than the GM kit, so .55 apose to .29. Yes, it's alot faster.
mensurSS's Avatar
na i dont have cooling mods, what do u guys suggest i work at getting next, maybe a cobra heat exchanger?
Old Jul 26, 2009 | 10:52 AM
A 2.8 well tuned isn't going to cause any probblems. Just heat soak faster till he gets a few cooling mods.
Old Jul 26, 2009 | 10:53 AM
mensurSS's Avatar
i went with the stage 2, the guy at gm said that he did many cobalts stage 2 kits and when he tests drives them its an amazing difference.
EatonTVS07's Avatar
OTT stage 1 comes with 60lbs injectors, 2.8 pulley and hub, shorter belt, canned tune, plugs maybe? but its cheaper so you can use the left over money to by cooling mods, i would suggest OTT's Heat exchanger as well.
The dual pass end plate is a good cooling mod or a heat exchanger
Old Jul 26, 2009 | 10:54 AM
EatonTVS07's Avatar
the thing about there tune though is that it runs really rich. like 10.5 i think or around there. so you should get a custom tune after.
Old Jul 26, 2009 | 10:55 AM
mensurSS's Avatar
now lemme ask u guys with the stage 2 kit what ballpark are we talking about, are we like cobalt tc fast? i would guess with 245 to the wheels that we are somewhere close to evo's? i could be wrong
Old Jul 26, 2009 | 10:57 AM
EatonTVS07's Avatar
probably put you around 235 the tunes not that good with the GM kit.
Old Jul 26, 2009 | 10:59 AM
mensurSS's Avatar
does the oem cobra heat exchanger bolt right up to our set-up?
ill look around new jersey to see if someone can istall and do a better tune then gm
occsdude's Avatar
maybe a stock one from a 40 mph roll but thats it. or at least i would think
Old Jul 26, 2009 | 11:00 AM
EatonTVS07's Avatar
i beleive so you may need to peice together some hardware. i have the OTT one which holds more coolant and bolts right up.
Old Jul 26, 2009 | 11:05 AM
mensurSS's Avatar
ok i think i might go with the ott exchanger just gotta wait a couple weeks to get some money
Old Jul 26, 2009 | 11:06 AM
EatonTVS07's Avatar
good deal, theres a how to on how to install it if you need instructions.
Old Jul 26, 2009 | 11:09 AM
mensurSS's Avatar
also a little off topic i should get some suspension mods how are those loweing springs that are on ebay?
