Spring's
Old Jul 26, 2009 | 07:08 PM
gomedan1's Avatar
Spring's
Will the 06' SS/SC spring give me a drop on a 06' LT?
Old Jul 27, 2009 | 08:43 AM
qwikredline's Avatar
yes........................
Old Jul 27, 2009 | 09:39 PM
gomedan1's Avatar
How much of an drop?
Old Jul 27, 2009 | 10:49 PM
SPRING DROPS OFF FORUM:
THEY SAY:
Rear will drop .25" to .5" -- that's all. Check CED website and get the purple tagged replacement SS springs -- they are .25" shorter then the original equipment springs. Factory original equipment SS springs have yellow tags on them.
Unless you get yourself some FE5 struts and Shocks to go with the SS/SC springs then you would get a
1.6" Front Drop and 1.3" Rear Drop. THIS IS NOT NECESSARILY TRUE
HERE IS WHAT I MEASURED:
STANDARD SS SC UNMODIFIED COBALT AT RIDE HEIGHT:
26 3/8 FRONT 27.5 REAR (TO FENDER)
GM say the ss/sc trims the car 10 mm less than the stock car. take that to the bank.
Old Jul 27, 2009 | 10:52 PM
znew's Avatar
just get aftermarket springs
i got eibach sportlines and love em
Old Jul 28, 2009 | 10:08 PM
gomedan1's Avatar
The reason i want to get the ss/sc spring is to buy the struts and shocks with it because i need them. Now if i buy the struts and the springs will i need to replace the strut mount, spring seat, spring insulator, and dust shield? Where is the best place to also buy these item's if i need them?
Old Jul 29, 2009 | 09:50 AM
395 plus's Avatar
NO you wont have to buy anything else the mount is the same. When I put on the SS/SC spring with stock shock I dropped 1" front and rear.
Oct 21, 2015 11:57 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
