question for GM tech supercharged ss motor/harness in LS
Old Oct 14, 2009 | 02:46 PM
stangetr's Avatar
hi , i'm not sure if this is the correct area for this question,
i have a 2006 ls and recently bought a complete 07 SS/SC
the question:
will i have any problems installing the engine, trans , computer and wiring harness, exhause? basically everything in the engine bay- or do i also have to change the complete interior harness? ?
please advise
thanks in advance
Old Oct 29, 2009 | 01:34 PM
jrocstar's Avatar
first off, why are you swapping if you have an 07 that is complete? second if you switch harness external and pcm you will be fine. the bcm and abcm are seperate modules and do not interact with one another for the most part. obviously going from a standard to a manual you can have problems arise. yes there is canbus systems in the vehicles but if you switch the pcm also it should be fine.
Old Nov 1, 2009 | 07:52 PM
stangetr's Avatar
i have an ls and bought a totalled ss/sc car, already did the swap- basically swapped everything, stripped mine to the shell the donor car also then rebuilt mine with all the ss stuff, car fired right up and is running great< thanks
Old Nov 1, 2009 | 07:59 PM
umrdyldo's Avatar
You swapped engine transmission and everything into your LS or just the supercharger setup?
Old Nov 2, 2009 | 10:06 AM
stangetr's Avatar
i swapped everything, the whole car was stripped to the bare bones and everything installed from the donor car
Old Nov 2, 2009 | 10:39 AM
umrdyldo's Avatar
Well I think you may be the first to do it. Cause that sounds like a hell of a job.
Old Nov 2, 2009 | 11:39 AM
383_Stroker's Avatar
awesome!
I wanna give you a hug...
Old Nov 14, 2009 | 11:01 PM
XM15's Avatar
Saw the car today. Pretty cool stuff.
You're the first guy I've heard thats done this.
brandon04
Oct 21, 2015 07:04 AM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
z28addiction
Sep 28, 2015 12:03 AM
