ZZP releases 78# valve springs for under $200!
Old Oct 27, 2009 | 02:48 PM
Zooomer's Avatar
Supporting Vendor
http://www.zzperformance.com/cobalt_...1112&catid=143
We also have exciting news on the installation of valve springs at ZZP! Check our our services section for another industry first and exclusive!
Old Oct 27, 2009 | 06:25 PM
elecblue06's Avatar
hmm verry interesting makes me think i can get some springs that much sooner
Old Oct 27, 2009 | 07:01 PM
ebristol's Avatar
Wow. That is cheap.
How are these different then the 78# Supertech Springs? Other then $100.
Old Oct 27, 2009 | 07:10 PM
cli3e0339384398jk's Avatar
interesting
Old Oct 28, 2009 | 09:07 AM
Jn2's Avatar
Jn2
L61 compadable? No 2.2 love?
Old Oct 28, 2009 | 09:29 AM
gearhead07's Avatar
did u read the link?
Old Oct 28, 2009 | 10:39 AM
elecblue06's Avatar
no he probably didnt .. he's more fail then fail itself
Old Oct 28, 2009 | 10:42 AM
BYT*SS*TURBO's Avatar
Damn I wish I was near ZZP. Thats a hell of a deal for ~$500 installed!
Old Oct 28, 2009 | 11:29 AM
Jn2's Avatar
Jn2
Ah ok. Didn't read the red. Only saw they said in the main body it's for the lsj and le5...
Old Oct 28, 2009 | 03:39 PM
Zooomer's Avatar
Supporting Vendor
Originally Posted by ebristol
Wow. That is cheap.
Supertech uses a dual spring. The outer spring is similar to stock but made slightly larger with thinner wire. It's pressure is about the same as stock. This allows them to put a small inner spring around 20# in there to increase pressure. The downside is the loss in clearance, the supertech's will coil bind at .455 lift (not an issue for most).
ZZP had a custom spring made to replace the stock unit. Our part has stiffer coils to increase weight which eliminates the need for a center spring. with a stock retainer ours bind at .450 and with optional retainers .475
Old Oct 28, 2009 | 11:18 PM
elecblue06's Avatar
i'm guesing this is what you guys run on your cars?
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 21, 2015 11:57 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Sep 28, 2015 02:46 PM
