higher compression ratio = bad for N20?
is a high compression ratio bad for nitrous?
what about new cams? (do they effect n20 at all?)
**btw i have a 2.4 and am interested in putting new piston heads and cams in**
well from a 50 shot a 50hp gain is an estimate, although you'd never know for sure unless you hopped on a dyno.
i would suggest maybe running through a nitrous sticky on another forum if you're on one and look at all you're going to need to run it safely.
basically you want a wet kit, 2x colder plugs, msd window switch, bottle heater, purge.
