INTENSE-Racing.com Intense Racing is a proud Supporting Vendor
Ported Blowers?
Old Jun 28, 2006 | 02:05 AM
silverSS's Avatar
Ported Blowers?
What kind of gains are we looking at here?
or any more information than what is listed on the site, I and many other members are interested.....
Old Jul 4, 2006 | 02:02 PM
silverSS's Avatar
Awesome!
Old Jul 12, 2006 | 10:19 AM
adam0416's Avatar
Porting a blower is the equivalent to porting an intake manifold of a turbocharged engine. You'll be able to make the same power at less boost or more power at same boost. If you add boost, you'll have even greater gains. If I were to guess, I'd say 15-20hp on stock boost setting of 12psi. Add 5 psi and you should see gains of 30-40hp and if you add a 2inch primary runner/3 inch collector header with a 3inch exhaust and a nice CAI you should see peak gains with that blower running at 17psi. Of course, this is with a tune. If this is not satisfying to you, port the head and put Tri-Cams in and you should be WAY over 300whp. Which is enough power to be classified in "ball-busting acceleration".
Old Sep 17, 2006 | 12:06 PM
Yodair8's Avatar
Curious about cost...
Old Sep 17, 2006 | 12:09 PM
Allshot's Avatar
Intense ports superchargers
Old Sep 17, 2006 | 12:11 PM
cobaltBlackss's Avatar
I'm seeing 21 lbs of boost with my 2.5" pulley. Thats two more than if my blower wasn't ported.
Old Nov 17, 2006 | 11:37 PM
Spinner's Avatar
The M62 doesnt have a significant restriction in the outlet path of the blower. Ported or not, you can still only make as much boost as your rotors will support.
Old Nov 18, 2006 | 12:29 AM
bdwarr6's Avatar
you guys realize boost is nothing but restriction?
more may make more power but the same power at less boost is better
Oct 13, 2015 09:32 PM
jimbofug007
Oct 2, 2015 12:06 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
