Removing the stock shift knob on a SS
Old May 14, 2005 | 11:21 PM
codyss's Avatar
Mine is not straight on for some reason how do you remove it?
Thanks
Old May 16, 2005 | 03:22 PM
tiny's Avatar
and similarly on a 5 spd ls sport coupe also?
Old May 17, 2005 | 06:20 PM
codyss's Avatar
Well I guess they are pressed on and can be pulled off but it will take a bit of muscles.
Old May 26, 2005 | 05:31 PM
Maven's Avatar
Its not as easy as other knobs unfortunately....Remove the emblem from the top of the shifter knob. Cut away the protector in the center. Mark and drill a 4 mm hole, 5 mm deep into the knob, 3 mm from the edge. The knob can be removed by screwing a self-threading plate screw with a flat tip (25 x 5.5 mm) into the hole.
Remove the shifter knob from the shiftier spline and shifter assembly.
to install:
Apply adhesive to the knob.
Seat the shifter knob over the shifter lever. Ensure the spring and foam rings are correctly seated.
Do not operate the lever until the adhesive(Loctite 292 or similar) has dried (approximately 30 minutes).
Position and fit the emblem over the shifter knob. I dont know why it has such an elaborate shifter...I think the B&M shifter is the way to go...I dont know if its available yet.
Old Jul 23, 2005 | 01:38 AM
JimmiLS05's Avatar
all that just to change a shift knob... screw that lmao
Old Jul 23, 2005 | 01:46 AM
Guess I will not be changing the shift knob any time soon
Old Jul 23, 2005 | 01:48 AM
MarcS's Avatar
The Stig
I was looking at a Hurst T handel shift knob. I suppose I'll be keeping it stock.
Old Jul 23, 2005 | 12:30 PM
JimmiLS05's Avatar
but a spring for a 5speed shifter?
Oct 27, 2015 01:27 PM
Oct 21, 2015 11:57 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
