Front Page News Site Polls
Georgian Bay Motorsports Cobalt takes another 1st Place
Old Jun 19, 2005 | 12:30 PM
<img src="http://www.cobaltss.org/pix/grandamcobalt-icon.jpg" align="left" border="0" hspace="5" vspace="5">The #00 Georgian Bay Motorsports Cobalt SS/SC edged out the SpeedSource Mazda RX8 for another win this weekend at Mosport International Raceway. From what I have read it appears the RX8 and the Cobalt SS/SC duked it out up until the last laps of the race and the Cobalt just took the checkered flag.
If you want to read more notes about the race or see the results check out Motorsports.com
Race Notes
Race Results
Old Jun 19, 2005 | 12:57 PM
JonyyB's Avatar
Site Founder
good find Rob! Also see:
http://www.speedtv.com/articles/auto/roadracing/17677/
Old Jun 19, 2005 | 02:41 PM
philco_3's Avatar
Proud Playstation 3 Owner
i would like to know where he got the wheels at. they look awesome on that car.
Old Jun 19, 2005 | 03:37 PM
DomesticDemonSS's Avatar
Bad @ss!! That's what I like to see. I hope they continue their improvements, this a great thing to see.
Old Jun 19, 2005 | 07:56 PM
RedCavyRS99's Avatar
damn the two cars i want battling it out to the end on the track that just makes me all warm and tingly inside
Old Jun 21, 2005 | 10:51 AM
Cam9730's Avatar
Does anyone have any 1024x768 pics of the Grand Am Racing Cobalts?
Old Jun 21, 2005 | 12:37 PM
Nope, you can try the Grand AM Cup website or SpeedTV website. I found a couple there but nothing high res.
Old Jul 5, 2005 | 11:26 PM
chaz1's Avatar
Pictures of Cobalts from all the Grand Am Races
All,
Try Webshots to get pictures of the Cobalts racing in Grand AM Cup:
http://community.webshots.com/user/thewazz48
Got all the races
Old Jul 7, 2005 | 06:32 PM
n4ggs's Avatar
they wont fit a stock cobalt, that race car has the suspension knuckles from the pontiac g6, bolt pattern and all.
Old Jul 13, 2005 | 06:05 PM
takacs87's Avatar
actually your are wrong the suspension knuckles are not from the G6, they are stock
Old May 22, 2014 | 07:46 PM
HPVO engineer's Avatar
The knuckles are G6 but the wheel bearings are 1999- 2001 Grand AM 115mm x 5 bolt pattern. Needed these wheel bearing speed sensors to work with the 2006 ABS system. Enchi wheels purchased from discount tire direct. They were US bolt bat tern as I remember 5 9/16 but closet to 115mm.
Old May 22, 2014 | 07:51 PM
The Turbo SS knuckles are close to the G6 and the wheel bearings and axle shafts were upgraded from the race program. Note the ball joint is .020in larger on the turbo knuckle so if you wanted to upgrade to the turbo system you would have to also install the lower control arm or ball joints from the turbo.
Old May 22, 2014 | 08:39 PM
Powell Race Parts's Avatar
the grand am enkei wheels RF1 were 5 x 114.3 or 4.5 inches nominal which is the same as the grand am wheel bearing. The ball joint post is 19. mm nominal on the LSJ and 20.0 mm nominal on the LNF so its just a question of opening up the LSJ knuckle to fit LNF arms, or retorquing to factory spec to fit LNF knuckles to LSJ arms.( 37 ft lbs reverse 3/4 turn 37 ftlbs again + 30 degrees.) The G6 knuckles install either way on the arms, the grand am wheel bearing needs a spacer in addition to the stock spacer to center the caliper on the rotor, be it Brembo caliper or LSJ caliper, the spacing is different for each of these two calipers when upgrading the LSJ to use LNF axles.
BTW that zombie thread you resurrected was from 2005.
roadrunner132
Sep 19, 2015 04:35 PM
Dope_SS
Sep 13, 2015 05:24 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Sean Cummings
Sep 11, 2015 09:35 PM
