Nitrous Oxide N20
NOS Jet Sizes?!?!?!?!?
Old Sep 25, 2006 | 11:46 PM
NVMYCOBALTSS's Avatar
Question NOS Jet Sizes?!?!?!?!?
dumb question time, What are the jet sizes for a 50 shot with a single fogger nozzle? I looked at NOS's page, they list .018F, .018N for the 4cyl nozzle kits. But that doesn't seem right. I think that those numbers may be for a direct port setup.
Who out there is running a baby hit of spray, and what jet sizes are you using. I am used to big bottle enhancements and do not have the pill sizes anywhere for a shot less than 200... HELP!
Old Sep 25, 2006 | 11:54 PM
uthinkimodd's Avatar
I cant really help you with the nos question and not wanting to steal the thread but i see you're from louisville and you're a dubber.
are you on clubvwoflouisville??? I'm on there under the same name not so much anymore since i moved away. but I own a VRT
I'm also looking at spraying my SS so this info could come in handy for me too.
Old Sep 25, 2006 | 11:59 PM
No, the vdub is my best friends car... we normally go to the track and see who is king for the day... It is a quick little car for what it is though and the torque is comparable. We built a rabbit truck that is a total basket case. It was a real disappointment for the money invested... wrong tranny, geared way too low for anything other than a cool burnout in 2nd gear.
Old Sep 26, 2006 | 12:03 AM
Old Sep 26, 2006 | 12:05 AM
lol ok well i doubt you're going ot get much info this late at night..
since I started rebuilding my dub I've been beating up on all the local ones around here it's a pretty good time.
Old Sep 26, 2006 | 12:08 AM
probably not... but worth the try, If I find out, I can have drew order and have all installed by wed before it rains... just need the pills. hell worst case snenario, I make the 2 hour drive to bowling green tomorrow to visit holley...
Old Sep 26, 2006 | 12:10 AM
Old Sep 26, 2006 | 12:20 AM
you dont have to bump this late at night not enough people post you'll stay on the top of the front page for a long time. just let it fester for about an hour then check it again.
Old Sep 26, 2006 | 12:22 AM
kewl... thanks, going to bed anyway, will check in tomorrow,.
Old Sep 26, 2006 | 12:38 AM
Bika's Avatar
Fail Less.
18 fuel and 31 n2o is a 50shot for NX systems. the jet sizes are gonna be the same across brands as the numbers are the actual size in thousandths of an inch, indicating how large the opening is.
Old Sep 26, 2006 | 05:34 PM
slowion2's Avatar
typically yes, but keep in mind different kits design their jets around different pressure levels ( 900psi vs 1000psi ), so it's a good idea to check with the brand name that you have. N.O.S. should have it on their site somewhere in a manual you can download anyway, otherwise most muscle car shops have a chart for them and NX at least since they are very popular.
Old Sep 26, 2006 | 11:07 PM
thanks a bunch.
Old Jun 16, 2009 | 03:32 PM
hawlyns711's Avatar
can anyone verify this for me?
^^bump bump anyone??
Last edited by hawlyns711; Jun 16, 2009 at 03:32 PM. Reason: Automerged Doublepost
Old Jun 16, 2009 | 06:33 PM
I found a jet size calculator...
http://www.robietherobot.com/NitrousJetCalculator.htm
This is a 40psi of fuel and 900 psi of bottle pressure.
Results
The Fuel jet size should be 0.018" or 0.446mm
A Nitrous jet size of .031" or 0.7874mm should produce:
43.40 HP with 1 port(s)
Actual HP to the wheels: 36.89 HP
Old Jun 17, 2009 | 07:54 AM
hawlyns711's Avatar
I thought stock LSJ fuel pressure was 58-62 psi at the rail? sorry man, just trying to get this straight dont want to end up with a 100 shot lol...
Old Jun 18, 2009 | 11:28 PM
62 psi
The Fuel jet size should be 0.015" or 0.390mm
The best way would be to measure the fuel pressure at the rail to double check. I am not sure what the actual pressure is. by using 40psi as a base, the fuel jet will be larger (fatter) and the shot will be somewhat safer. Leaning out = BOOM!
Old Jun 20, 2009 | 02:29 PM
usmc6212's Avatar
for my zex kit it is a .017 for fuel and a .032 for nitrous but that is for a 55 shot
http://www.zex.com/Pages/71/Jet%20Charts.aspx here is the chart
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 26, 2015 06:44 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
