NOS Jet Sizes?!?!?!?!?
dumb question time, What are the jet sizes for a 50 shot with a single fogger nozzle? I looked at NOS's page, they list .018F, .018N for the 4cyl nozzle kits. But that doesn't seem right. I think that those numbers may be for a direct port setup.
Who out there is running a baby hit of spray, and what jet sizes are you using. I am used to big bottle enhancements and do not have the pill sizes anywhere for a shot less than 200... HELP!
I cant really help you with the nos question and not wanting to steal the thread but i see you're from louisville and you're a dubber.
are you on clubvwoflouisville??? I'm on there under the same name not so much anymore since i moved away. but I own a VRT
I'm also looking at spraying my SS so this info could come in handy for me too.
No, the vdub is my best friends car... we normally go to the track and see who is king for the day... It is a quick little car for what it is though and the torque is comparable. We built a rabbit truck that is a total basket case. It was a real disappointment for the money invested... wrong tranny, geared way too low for anything other than a cool burnout in 2nd gear.
probably not... but worth the try, If I find out, I can have drew order and have all installed by wed before it rains... just need the pills. hell worst case snenario, I make the 2 hour drive to bowling green tomorrow to visit holley...
18 fuel and 31 n2o is a 50shot for NX systems. the jet sizes are gonna be the same across brands as the numbers are the actual size in thousandths of an inch, indicating how large the opening is.
typically yes, but keep in mind different kits design their jets around different pressure levels ( 900psi vs 1000psi ), so it's a good idea to check with the brand name that you have. N.O.S. should have it on their site somewhere in a manual you can download anyway, otherwise most muscle car shops have a chart for them and NX at least since they are very popular.
^^bump bump anyone??
Last edited by hawlyns711; Jun 16, 2009 at 03:32 PM. Reason: Automerged Doublepost
I found a jet size calculator...
http://www.robietherobot.com/NitrousJetCalculator.htm
This is a 40psi of fuel and 900 psi of bottle pressure.
Results
The Fuel jet size should be 0.018" or 0.446mm
A Nitrous jet size of .031" or 0.7874mm should produce:
43.40 HP with 1 port(s)
Actual HP to the wheels: 36.89 HP
Results
62 psi
The Fuel jet size should be 0.015" or 0.390mm
The best way would be to measure the fuel pressure at the rail to double check. I am not sure what the actual pressure is. by using 40psi as a base, the fuel jet will be larger (fatter) and the shot will be somewhat safer. Leaning out = BOOM!
for my zex kit it is a .017 for fuel and a .032 for nitrous but that is for a 55 shot
http://www.zex.com/Pages/71/Jet%20Charts.aspx here is the chart
