JBP 4-Pass Intercooler
Old Oct 17, 2006 | 01:33 PM
JBP's Avatar
JBP
Canada JBP 4-Pass Intercooler
Folks,
We're happy to announce our 4-Pass intercooler for those running high boost, high temperatures.
Our 4-Pass intercooler is JBPs gift to those who want to retain stock look, with the best cooling possible for high boost, high temperature builds. We've employed 4 specialty laminova tubes, internal passageway mods and engineering know-how to develop our 4-Pass Intercooler.
The nice this about this upgrade is that it is the stock unit revamped. Stock appearance, with double the flow, and close to triple the cooling effect with a 4-pass intercooler. There is no need to upgrade the aftercooler or any other part of the supercharger cooling system once this is in place.
Pricing for the 4-Pass intercooler will be approximately $429CDN. and will include the following:
- 4 Specialty Laminova Tubes
- Replacement High Flow/Volume Pump
- Replacement Stainless Braided Steel Coolant Lines
- Modified Coolant Outlet Ports
- Double Inlet Ports
- Instructions for installation
Customers ship us their stock Intercooler, we ship back the 4-Pass Intercooler, ready to install.
Old Oct 17, 2006 | 01:38 PM
distillion's Avatar
so this is like the dual pass gm stage 3 uses, only more effecient?
Old Oct 17, 2006 | 01:44 PM
JBP's Avatar
JBP
No, the Stage 3 is a 2-Pass, this is a 4-Pass.
Old Oct 17, 2006 | 01:46 PM
06black's Avatar
pictures???
Old Oct 17, 2006 | 01:47 PM
JBP's Avatar
JBP
Pics?... Hmm, I think you'll be disappointed since it looks exactly like the stock unit.
edit: with an extra 1" Russel fitting sticking out of it.
Old Oct 17, 2006 | 01:48 PM
Smarty Art's Avatar
Pictures and numbers!
Old Oct 17, 2006 | 01:49 PM
NoRemorse's Avatar
please define '4 pass'
does it go thorugh all 4 at once? because that is a single pass
if it goes through all in a serial manner, that is a 4 pass, how it is stock. the fluid makes 4 passes through the manifold.
Old Oct 17, 2006 | 01:52 PM
06black's Avatar
i'm more intersted in the high flow pump and steel lines you speek of.
Old Oct 17, 2006 | 01:54 PM
automobiliben's Avatar
So is that how people define the passes? I haven't heard anything definite yet, but everyone has been throwing around something different. Using your definition, I think what they are selling would be considered a 2 pass.
Old Oct 17, 2006 | 01:55 PM
JBP's Avatar
JBP
Actually, you have it backwards:
Stock SINGLE Pass, Single Inlet, Serial run.
JBP:
Stock QUAD Pass, Double Inlet, Double Parallel run.
Old Oct 17, 2006 | 01:57 PM
NoRemorse's Avatar
Also, I am a bit leary of a higher flow pump. If flow increases, more than liekly the pressure in the system will increase (the manifold might flow more now, but what about the stock HE? anything over 5psi, and the system leaks
EDIT:
Ok, well, the termionolgy for a 'pass' is actaully very debatable, but that is niether here nor there. the fact is you are running all 4 cores in parallele.
are there any logs to show improved IAT2s? This will increase flow, but decrease the time the fluid spends in the manifold, letting it 'absorb' less heat.
Just curious on how effective it is.
Old Oct 17, 2006 | 01:58 PM
JBP's Avatar
JBP
Hence the new provided lines.
JBP:
Maybe putting up a diagram would be very helpful. This is all getting very confusing, everyone is calling the passes something different. If you guys have just added one exit fitting, then everyone is referring to that as a dual pass.
Old Oct 17, 2006 | 02:07 PM
srt-killer's Avatar
What are the IAT 2 temps?
JBP's Avatar
JBP
When I have some time, I'll explain with a diagram so everyone has a clear idea as to what a 4-pass is.
Old Oct 17, 2006 | 02:39 PM
06black's Avatar
I'm excited for this!!!
any price idea?
Old Oct 17, 2006 | 02:45 PM
NoRemorse's Avatar
sorry, missed that part. pretty impressive package. Still raises the question about flow vs. time spent absorbing heat.
EIther way, I am sure it works very well. I would love to see some data logs!!!
Old Oct 17, 2006 | 02:47 PM
distillion's Avatar
listening....
if you say that an aftermarket heat exchanger isnt needed with this unit, im in 100%
Old Oct 17, 2006 | 02:50 PM
pierre's Avatar
JBP:
Sorry you have it backwards. Stock is 4 pass. Between the inlet and the outlet the coolant passes through 4 seperate laminova cores and has to go into a chamber to reverse its direction each time.
Pierre
06blackg85ss's Avatar
so two inlets (on what used to be the stock inlet and outlet) and one outlet ... in the middle of course... than that would be the dual pass setup... unless you got something else going on here... clue me in... I just did a dual pass on my car.. and saw a decent decrease in my iat2... is your setup different/more efficient... got any logs to show difference... not being a P.I.T.A. ... but I"m a glutton for info.
Old Oct 17, 2006 | 02:53 PM
DWK5150's Avatar
Did you ever rearrange your cores?
Old Oct 17, 2006 | 02:55 PM
Tomtwtwtw's Avatar
any price idea?
He gave the price on the original post.
Didn't get a chance this weekend... and next weekend looks like I gotta swap a tranny on one car and a motor on another... so... hopefully I'll get a new intake gasket in the process and get my car finished one of these days... still haven't put my rear tranny mount back in... sitting in my trunk for weeks now.
Old Oct 17, 2006 | 03:01 PM
pierre's Avatar
EDIT:
You will not see 5 PSI from any automotive intercooler pump in a working system. It's mostly thermal expansion that causes the pressure rise.
If you assume a perfect pump the time for the coolant to go all the way through 4 cores in series is the same as 4 cores in parallel.
Frankly I'd be more worried about balancing the coolant flow through 4 cores in parallel.
Pierre
Old Oct 17, 2006 | 03:10 PM
2K5SS/SC?'s Avatar
Holy **** I'm really confused right now. I need a diagram to follow this one.
