JBP 4-Pass Intercooler
Old Oct 17, 2006 | 03:19 PM
WSFrazier's Avatar
I just want to see some logs and see how low it takes the IAT2's.
Old Oct 17, 2006 | 03:28 PM
vandy0419's Avatar
Originally Posted by pierre
You will not see 5 PSI from any automotive intercooler pump in a working system. It's mostly thermal expansion that causes the pressure rise.
If you assume a perfect pump the time for the coolant to go all the way through 4 cores in series is the same as 4 cores in parallel.
Frankly I'd be more worried about balancing the coolant flow through 4 cores in parallel.
Pierre
Why won't we see 5psi from out intercooler pump? Some are rated at 5 and some at 3, but the Bosch are rated at 7psi...GM doc 1471156 states under the intercooler system that it is rated at 7psi...
Old Oct 17, 2006 | 03:32 PM
vandy0419's Avatar
And noremorse and pierre are right, stock it is a 4 pass. You stated that it looks stock EXCEPT for 1 addt'l fitting which means it is a 2 pass or dual pass. Two inlets (stock inlet and outlet) and a fitting tapping where the second and third intercooler cores transfer makes it a dual pass and that is the outlet. Or vice versa really with one inlet (new fitting) and stock inlet/outlet as new outlets.
There was a shop that did a build of the LSJ and did a dual pass, then a 3 pass but there weren't noticeable gains for the 3 pass to be worth it.
Reference to page 8 of link: http://manual.lsjowners.com/ecotec300hpbuild4.pdf
On the left is the dual pass, the right is the 3 pass.
Old Oct 17, 2006 | 03:33 PM
ptparker's Avatar
Because If you ever see 5-7 psi in your system, then you have a major bottleneck/restriction somewhere. If you plug somewhere in the line it may get up to 7psi, but that doesn't mean that is ideally efficient. Thermal expansion may get it up to 7, but that has nothing to do with the pumps rating. That is just the hot air/hot water pushing on the cap wanting to escape. I keep my cap on loose just to not let the thermal pressure build up.
Old Oct 17, 2006 | 03:34 PM
srt-killer's Avatar
Originally Posted by 06blackg85ss
so two inlets (on what used to be the stock inlet and outlet) and one outlet ... in the middle of course... than that would be the dual pass setup... unless you got something else going on here... clue me in... I just did a dual pass on my car.. and saw a decent decrease in my iat2... is your setup different/more efficient... got any logs to show difference... not being a P.I.T.A. ... but I"m a glutton for info.
The dual pass setup you are talking about is that the C/A H/E? How much did your IAT2 drop? It would be interesting to compare these two setups.
Old Oct 17, 2006 | 03:36 PM
vandy0419's Avatar
He's not dumb, he knows what he is talking about. He has a dual pass just like JBP is marketing, just not released yet by the other company!
Old Oct 17, 2006 | 03:38 PM
06blackg85ss's Avatar
I think I put a post about it up... but if not... I use it in conjuction with the c/a front mount... and I see during cruising an average IAT2 of 25-30 deg higher than ambient... I"m running a 2.5 pulley and with the meth my peak temps are around 130ish deg and the temp drops pretty much immediatly after a WOT run... maybe 2-5 min of reg driving and its back down to where it started... no more heat soak haha.... but I also have the meth injection which helps substantially. .
I think they'll have my logs posted on the site soon ....
sorry to hijack the thread JBP
Old Oct 17, 2006 | 03:39 PM
vandy0419's Avatar
I'm also curious of what is so special about the laminova cores? Our cores are made by Laminova in the stock intake manifold...
Old Oct 17, 2006 | 03:41 PM
Vette Jr.'s Avatar
this is a confusing thread... cant wait to see the diagram
Old Oct 17, 2006 | 03:46 PM
Serpico's Avatar
i think this information is a little missleading
4 Specialty Laminova Tubes
- Replacement High Flow/Volume Pump
- Replacement Stainless Braided Steel Coolant Lines
- Modified Coolant Outlet Ports
- Double Inlet Ports
- Instructions for installation
your really not including any additional intercooler tubes only offering some braided hoses and some fittings and some modifications to an oem system
not saying its not worth 430 $ but i was a little confused when i read it and then read the rest of the responces that were made
Old Oct 17, 2006 | 03:58 PM
  #36
Well... from my standoint... I do know the end cao (with the inlet/outlet) is pretty damn expensive... over $150 from gm..
Old Oct 17, 2006 | 04:02 PM
  #37
vandy0419's Avatar
Yeah...whats the point? We have to send them ours and then they modify it, so that $150 is nothing since they never have to buy one...not like a core swap or anything.
Old Oct 17, 2006 | 04:04 PM
  #38
AAAH.... I didn't see that part.... but I do know c/a (I know I know) is trying to do it on a core charge basis to keep costs down.... (I know sorry hijacker..)
Old Oct 17, 2006 | 04:05 PM
  #39
oh yeah and if they use good quality braided line... that **** is damn expensive in the -12an size that we have to use... plus those fittings priced are no joke... trust me on that... I"m using them
Old Oct 17, 2006 | 04:09 PM
  #40
vandy0419's Avatar
Are braided lines on an intercooler set up worth it though? Cost vs power efficiency?
Old Oct 17, 2006 | 04:16 PM
  #41
not really... but they do look good... lol/... but so far mine hasn't gotten hot enough.. or built up enough pressure to do anything to the plain rubber hoses... I actually have some of the stock rubber hose connecting to the resevoir cause I couldn't get the braided line to make the bend...
Old Oct 17, 2006 | 04:17 PM
  #42
also alittle added protection from road debris and whatnot... I use em and I'd keep em... due to the fact I drive through Queens and Manhattan everday
Old Oct 17, 2006 | 06:32 PM
  #43
pierre's Avatar
Vandy
Do you have a link to the GM document?
Pierre
Old Oct 17, 2006 | 06:46 PM
  #44
cvenom2122's Avatar
Thumbs up
Im def interested in a 2 pass system! i just got my cobra heat exchanger so this weill help even more!
Old Oct 17, 2006 | 09:40 PM
  #45
JBP's Avatar
JBP
Quite the number of posts since I last left off.
At any rate, the pricing is very reasonable for what is offered with the system. The replacement pump, lines, fittings are all very expensive as mention by a few members.
There also is a optional surge tank (pending design), that will be available near the end of the year.
We're very excited about this product, we see it as a huge seller.
Old Oct 17, 2006 | 10:37 PM
  #46
vandy0419's Avatar
Vandy
Pierre
PM me your email address and I'll email it to ya, Wop sent it to me in an email and I have it saved to my desktop so just PM me.
Old Oct 17, 2006 | 10:39 PM
  #47
vandy0419's Avatar
What kind of pump is the replacement pump though?
EDIT: Also, what is different about the laminova cores?
Old Oct 17, 2006 | 10:46 PM
  #48
R&C_rallySS's Avatar
I am looking very foward to seeing these charts/graphs. This would be one of the first mods I do after Stage II, smaller pulley, intake, exhaust. Should see some nice gains, car should run better. Specailly with a tune.
Old Oct 18, 2006 | 10:10 AM
  #49
JBP's Avatar
JBP
The pump is a centrifugal pump composed of heavy duty components. It is noticably somewhat noticably louder. The pump has more flow with a moderate beneficial increase in pressure. The pump is MANDITORY in order to run with the laminova cores, which have one extra liner to promote quick heat dissipation and a pressure increase because of the 4-pass parallel flow.
Old Oct 18, 2006 | 10:16 AM
  #50
sounds interesting
