Launching the Automatic - Brake Starting
Old Oct 24, 2006 | 01:15 AM
Halfcent's Avatar
I'm old school
With my automatic Cobalt and its modifications I am often asked how to launch it. So I thought I'd make a sticky about the technique known as Brake Starting. Most drag racing cars use automatics, and this is the technique they use.
The brake start works like this: With your car positioned on the start line, hold your regular brakes (not the parking brake) and place the car in gear. This simple act is called Brake Torqueing. Apply full pressure to your brake pedal.
Now go to Wide Open Throttle (WOT). Your tach will stop increasing at a particular RPM. That RPM is known as Stall Speed. It the fastest your Torque Converter will allow the engine to turn without the wheels turning.
At this point, release the brake pedal. Car takes off.
General notes:
This practice causes your transmission fluid inside the torque converter to absorb all of the torque from your engine turning when the wheels are not. This generates a lot of heat, and will destroy your fluid if you hold the Stall Speed any longer then necessary. Once you achieve stall, you should be releasing the brake within a second. Vehicles that use this technique should install an extra transmission fluid heat exchanger. They are rather cheap.
Brake starting should produce a cleaner initial start then a manual clutch can. The reason is due to the fact that the torque is already at the wheels before you even begin moving. Only your brakes are preventing the wheels from turning. A clutch start sends a jolt of torque through the trans and axles at the launch, which can create huge stresses on parts, causing things like the commonly known broken axle.
Brake Torqueing works on all automatic trans equipped cars, front or rear wheel drive. However, on a rear wheel drive, you probably won't achieve Stall. The rear wheels will more then likely start to turn due to the rear brakes not having enough clamping power to stop the power being delivered by the engine.
Cobalt Specific notes:
The stock stall speed on the 4T45E torque converter installed in the Cobalt is about 2400 RPM. Additionally, the converter is the weakest part of the transmission, designed only to accept about 250 ft/lbs of torque while the trans itself can handle about 320. A typical stage 2 turbo system that doesn't require you to upgrade your drive train in any way will work fine in a stock setup. Anything over 250 ft/lbs however should upgrade the converter to a heavy duty 3000 RPM stall.
The Cobalt has traction control which will interfere with this kind of launch. Different model Cobalts have different ways of turning this system off. On 2005-06 model year cars, the following method is used. Select first gear, or "L" depending on your model year. There is no difference in the transmissions, only the label on the gear selector is different. This will turn off traction control. Also, the Cobalt will shift to second gear during WOT acceleration even though you are only in first. After this shift occurs, slide the selector into second. This won't change anything except to allow the car to shift to third. Just like before, even though your are in second, it will still up shift one gear. It will not shift to third however if only first gear is selected. Once the car is in third, select "D"
On 2007 model year and up cars, turning traction control off varies. Check your manual. Some cars have an actual, simple button on the dash to turn it off, which is nice and easy.
The 4T45E has an open differential. Brake starting will probably result in one wheel spinning while the other one stands still. Without an LSD, you will need to practice your starts and vary your brake torqued throttle launch speed to get good launch traction.
Old Oct 24, 2006 | 04:20 PM
sushidog's Avatar
Thanks Halfcent! Great write up.
I have a 2.4 manufactured in 1/06 that has a tranny oil cooler built in to the bottom of the radiator. I hear other 06's manufactured mid year, and the 07's don't.
Do you know when the cut-off date was?
Old Oct 24, 2006 | 04:31 PM
Jackalope's Avatar
Good stuff!
Thats odd about the trans cooler as I'm showing the 07's DO in fact have a cooler built in. Its in the drivers side radiator tank. I'll double check on my 07 when I get off work but if it doesn't have one then its the only GM automatic I know of that doesn't. As far as I know ALL GM automatic transmissions have coolers built into the radiators.
Old Oct 24, 2006 | 04:37 PM
sushidog's Avatar
Originally Posted by Jackalope
Good stuff!
My bad! It's the oil cooler that the 07's lack. Sorry for the confusion.
Old Oct 24, 2006 | 04:38 PM
wdsoccer's Avatar
Ive tried this when i raced my friend in his Mazda 3 (i only held the gas at 1500 RPMs) It does have a lot quicker take off. Good write up.
Old Oct 24, 2006 | 05:20 PM
Jackalope's Avatar
Thats cool! I thought thats what you ment but I didn't want to put words in your mouth.
Yeah I WISH mine had an oil cooler! LOL!
Old Oct 24, 2006 | 06:34 PM
Halfcent's Avatar
I'm old school
All of our cars do have a factory trans fluid cooler, but you should STILL get an additional one if you plan to race with it. The fact that our transmissions have the factory cooler makes hooking up an additional one very easy. The fluid lines are already right there.
Old Oct 24, 2006 | 07:07 PM
BlackLS's Avatar
Do you have any recomendations for brands of tranny coolers and where and how do they mount and hook up?
Old Nov 23, 2006 | 04:14 PM
Halfcent's Avatar
I'm old school
B&M makes excellet heat exchangers. They are easy to install. The hardest part is getting the fluid lines cut and fitted to right length. Any good shop should be able to fabricate them for you.
Old Nov 23, 2006 | 05:10 PM
HunterKiller89's Avatar
well, i just saw your thread here from a post you just made which referred to this one...so, i have a couple questions....
1) the whole process of [floor the brake] [hit the gas (bout half way? or does this technique not eliminate traction issues)] [release brake] should take one second?
2) you wouldnt have a picture of where the tranny cooler hooks up would you? since im totally new to cars n all....
Old Nov 23, 2006 | 05:55 PM
Cirrus's Avatar
The time between you getting on the gas and releasing the brakes should be less than one second. And make sure the brake is as far as it goes down, I've done it several times and anything less than fully floored does not hold my car
Old Nov 23, 2006 | 06:06 PM
ORT's Avatar
ORT
Great write up Halfcent! You always have great info and are great help here!
I have heard from Brian Mitchell, who I don't know if anyone has heard of him but he bracket races (i beleive) mustangs and is among the top of his class, That unless your car is running slicks and putting out great power that it is better for you to take off like your at a red light. Im guessing to avoid wheel spin/hop. He said it can lower your 1/4 mile times by a few tenths of a second.
Old Nov 24, 2006 | 10:30 PM
ReggaeRampage's Avatar
The Cobalt has traction control which will interfere with this kind of launch. To overcome that problem, select first gear, or "L" depending on your model year. There is no difference in the transmissions, only the label on the gear selector is different. This will turn off traction control. Also, the Cobalt will shift to second gear during WOT acceleration even though you are only in first. When this shift occurs, slide the selector into second. This won't change anything except to allow the car to shift to third. Just like before, even though your are in second, it will still up shift one gear. It will not shift to third however if only first gear is selected.
Are you saying that once you have this automatic in 2nd gear in "L", you can switch to "I" without possibly messing up the tranny?
Old Nov 27, 2006 | 10:30 AM
Old Nov 27, 2006 | 10:35 AM
HackAbuse's Avatar
Of course you can you can move the shifter anywhere but 'Park' and 'Reverse' while you are moving without damaging anything
Old Nov 27, 2006 | 11:12 AM
BossHogg's Avatar
I just dont understand how it cant mess nothing up bumping up the shifter. Maybe if you switch out to one of those aftermarket brank tranny fluids, like B&M, Royal Purple, or Hurst, would that help any? Or is it a waste of money for the automatics?
Old Nov 27, 2006 | 11:32 AM
red_wing_2121's Avatar
How about when autocrossing. Should auxiliary trans cooler be used?
Old Nov 27, 2006 | 01:36 PM
Halfcent's Avatar
I'm old school
I realize it's a difficult concept to read and understand, but if you just go out and do it once, you'll see how it works. Here, do this:
Go out on some open road. Put your car in normal old ordinary "Drive" and floor it. The car will accelerate in first gear all the way to around 6500 RPM where it will shift automatically to second and continue accelerating. Just like it should.
Now...One more time...Try this...
Put the gear selector in first or low depending on how your selector is labeled. Its the furthest position back you can move the selector.
Floor it. The car will accelerate in first gear all the way to around 6500 RPM where it will shift automatically to second and continue accelerating. EVEN THOUGH THE SELECTOR IS STILL IN FIRST! Then, simply continue accelerating at WOT and slide the selector up to second. NOTHING WILL HAPPEN. The car is already in second and still accelerating. Doing this will allow the trans to now shift to 3rd, EVEN THOUGH THE SELECTOR IS STILL IN SECOND!
The whole purpose of doing this is to turn T/C off for your launch. That's it!
Old Nov 27, 2006 | 01:48 PM
BossHogg's Avatar
dude, im an idiot or still hung over but what the hell does WOT mean
and Halfcent, if you could tell me if changing fluids would help....you seem to know the most, thanks
Old Nov 27, 2006 | 01:55 PM
Cobalt443's Avatar
WOT = Wide Open Throttle
Old Nov 27, 2006 | 02:13 PM
Maximum torque rating is 270 Nˇm (200 lb ft) as stated in the GM general specifications of the 4T45E.
I can upload the information as I did with the 2.2L engine specs that I have in my picture gallery right now, if you would like (check my gallery to see what I am referring to. Page 3, I believe).
Old Apr 21, 2007 | 09:55 AM
TCarter's Avatar
Ok kids, in short. if you drag race your car, pull up to the burnout box...do your thing....go stage. left foot on the brake, right foot on the gas, shifter in L(or 1).
Why not I or D? Simple. L = No Traction Control. The traction control in these cars are very limiting when it comes to giving the driver control of the throttle again.....it cuts throttle for approx 1 sec.
So, Amber..Amber...Amber(i let off the brake here)....GREEN (i average .05 R/T's)....still in L.....go all the way through 1st, then at the top of second, shift into I.....then finish the race....since in my SS, I = 120+ish.
Old Apr 21, 2007 | 11:40 PM
BlackLS's Avatar
Do all automatic Cobalts have traction control because i don't think mine does? And how can one tell if it does have traction control?
Old Apr 22, 2007 | 12:06 AM
cobaltssTH's Avatar
so you finish the race in I.
Old Jun 3, 2007 | 05:26 AM
rycobaltls22's Avatar
My baby (stock '06 Cobalt) had her first kill ('97 Sunfire MTX w/ CAI) using brake starting. I used to use it on my 2000 Neon and it works wonders.
