Need HELP w/ GM intake install
Old 11-25-2006, 02:49 PM
ReggaeRampage's Avatar
OK, I pieced together almost the entire thing BEFORE putting it into my car. So all I have to do is pull out the stock tubing, airbox, and valve cover, right?
But what the hell is this thing (tube) connected to the airbox on the right? There's no mention of that in the instructions. And where do I put it after I drop the new airbox in?
Old 11-25-2006, 03:19 PM
I'm old school
Halfcent's Avatar
You sir, I'm afraid to tell you, are screwed.
That is the secondary air injection supply line, which was added to late production 2006 model L61 cars. And your right, the GMPP intake doesn't provide for it. I'm afraid you won't be able to use your intake.
Read this:
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
Well, you could use the intake, but then you will need to somehow filter the air entering that air pump line once you disconnect it.
At present, K&N is the only aftermarket intake manufacturer I know of that provides for SAI.
Old 11-25-2006, 03:28 PM
hardtocope's Avatar
huh? i thought the gm intake works with all 2.2 and 2.4 from 05-07?
Old 11-25-2006, 03:34 PM
FU(K!!!!
That sucks!
Will Crate Engine Depot take returns on opened parts?
Old 11-25-2006, 03:36 PM
HackAbuse's Avatar
I put an intake on my friends car and left that tube hangin
Old 11-25-2006, 03:38 PM
lol...I don't know about that. The whole point of getting that intake was to NOT void my warranty.
Old 11-25-2006, 03:39 PM
HackAbuse's Avatar
Bring it to the dealer and have them install it, they'll figure somethin out
HackAbuse's Avatar
BTW, how are your luminics bulbs?
Got any pics?
Old 11-25-2006, 03:40 PM
They want $300 to install it! I don't think that's going to happen.
Old 11-25-2006, 03:44 PM
I'm old school
Halfcent's Avatar
Yeah, they'll figure out that it doesn't fit, hand it back to you and tell you it doesn't fit.
Old 11-25-2006, 03:46 PM
Got any pics?
My driver-side High Beam blew out already.
The pictures don't really help show how blue they really are, but I posted some on the 2nd page of this thread:
https://www.cobaltss.net/forums/appearance-48/blue-bad-32693/
Old 11-25-2006, 03:47 PM
lol...You, my friend, can tell the future.
Old 11-25-2006, 04:00 PM
iLLmaTic3s's Avatar
thats insane. 300 bucks. to install that..its like 20min job.
Old 11-25-2006, 04:02 PM
I asked how many hours they would charge for? He said 3+ hrs.
For an intake?!
Right now, I am PISSSSSED!
Advice anyone?
R&C_rallySS's Avatar
And then charge you 400.00 bucks for labor that never happened.
Screw it man, buy a injen intake. I think those will fit your car fine. Not sure, may want to ask the x-perts on 2.2 or 2.4 w.e u got.
Old 11-25-2006, 04:03 PM
HackAbuse's Avatar
It took me ten minutes to install my Injen SRI
Old 11-25-2006, 04:06 PM
INJEN was my 1st choice. Except now I know that won't work either.
The only thing that works is K&N, doesn't that throw CELs?
Old 11-25-2006, 04:21 PM
I'm old school
Halfcent's Avatar
K&N is the only option for you if you really want an intake. And yes, they seem to produce the highest number of CEL's. It seems to be a result of the oiled filter element contaminating the MAF. You could use the K&N system with a dry filter, and just replace the element regularly like everybody else.
As for your GMPP intake, call Tom and see what he can take back. If not, list it in the Classifieds.
OR, if you want to get fancy, try fabricating an attach point onto the new intake for the SAI line. The current system taps to filtered air. If you attached it to the side of the new intake air box, that would be unfiltered, but I don't think that would be bad. Better then just letting it hang. If you attached it to the intake pipe, be sure it is upstream of the MAF.
Old 11-25-2006, 04:29 PM
Man, I can't believe this. This was supposed to be my 1st performance modification ever, and this $hit happens.
This kinda discourages me from doing anything at all. Especially when that's a GM part MADE specifically for this car. And since K&N throws CELs & would void my warranty, why even bother at all?
I always thought about getting their exhaust. But now I have to 2nd-guess that too. Is there anything else I'm missing before I even START to think about that? I'm so bummed out right now...
Old 11-25-2006, 04:32 PM
Mercury's Avatar
You could always modify the intake to work.
Drill a hole, screw in a nipple and get some silicone tubing. Should only cost you about $10 in parts at pepboys.
Old 11-25-2006, 04:34 PM
HackAbuse's Avatar
drill a big hole, then tap it, then screw a pipe fitting into it, then connect the tube to that
Old 11-25-2006, 04:35 PM
HackAbuse's Avatar
Damn, you beat me to it
Old 11-25-2006, 04:38 PM
GM will void warranty if something comes up and they find that. I'm not taking the risk. If it didn't matter, I would try to modify it. Believe me.
Old 11-25-2006, 05:02 PM
I'm old school
Halfcent's Avatar
Okay, breathe, relax, GM is not going to void your warranty. If you have an aftermarket intake and it throws a CEL, that doesn't void your warranty either. You'll be fine.
Now, about the exhaust you want to do. This is EXACTLY the reason for belonging to a forum like this.
What do you want to do? I can't tell from your post. You want to put on an aftermarket exhaust of some kind? Ok, here's what you can do:
You can not change your manifold. It also is part of the SAI system.
You need to be careful about the downpipe. The SAI cars have a weird cat on them, and recently people have posted that they have 2!
However, any cat back system should be fine! This would replace the resonator and muffler and of course the piping.
Next idea:
You have the GMPP intake. Hold on to it for a while.
Get an aftermarket header, and then remove the SAI system completely!
Nobody I know has done that yet, but the idea is sound. It is believed that removing the system completely would result in a CEL, but nobody has tried it yet. However, despite the CEL, you would have a perfectly operational engine with no hazards at all.
BTW, none of these changes would be legal in California because of their stupid ass CARB law, but it would be fine everywhere else. Perfectly legal.
Old 11-25-2006, 05:13 PM
tonio5555's Avatar
Next idea:
I'm considering trying out the GMPP intake w/ LSJ manifold on my SAI equipped 2.2 Cobalt. If I do it I will use the GMPP Intake as well as an LSJ Manifold and downpipe so that the entire SAI system will essentially be deleted from the car. If the SAI setup is designed to improve emissions would replacing the O2 sensor so a non SAI O2 sensor prevent a CEL?
Quick Reply: Need HELP w/ GM intake install
