ECU swap?
Old Apr 18, 2007 | 03:21 AM
Archie's Avatar
ECU swap?
I have a 2.2L, and plan on supercharging after a bit. I was wondering if anyone forsees any problems swapping a 2.0ECU in place of the 2.2L. The reason I ask this, is that it seems it would be easier, and safer, to swap ecu's so that I can tune safely, w/o piggyback.
I would probably have to swap all sensors too since the 2.2 only reads bar1 right?
I have read that the 2.0L ECU does have the capabilities of controlling an auto transmission. Can anyone confirm?
Old Apr 18, 2007 | 09:36 AM
Sw4y1313's Avatar
Its not possible to swap. The computers dont read the same even if you "swapped all the sensors". If it were possible, it would have been done already. Your stuck with waiting for HPT or SCT, or going piggyback.
Old Apr 18, 2007 | 01:09 PM
Archie's Avatar
What do you mean they don't read the same? They are computers designed to run off of a bunch of sensors, and use "yes" and "no" to change things. I know my ecu and the SS/sc ecu must be similar now, because for 05-06 ls they used a 16bit processor, and for 07 they switched to a 32 bit processor, the same power as an SS ecu.
If you could explain a little more, that would be appreciated.
Old Apr 18, 2007 | 03:12 PM
VaMP's Avatar
Sw4y is right, it's not possible. The SS SC ECU is tuned for 2.0L of displacement, throwing in an extra .2L would severely screw up your engine. GM has spent COUNTLESS hours tuning the 2.0L ECU for that specific engine. You're better off going with a custom ECU or a piggy back system.
Old Apr 18, 2007 | 03:47 PM
Sw4y1313's Avatar
I believe Witt has explained this much better a couple months back. Use the search button and look it up. Im telling you, the computers are completely different. It doesnt have anything to do with displacement, it has to do with how the computer operates when reading the sensors. It wasnt designed for the L61, its not gonna work. Im not tryin to knock you down or anything, but it just isnt possible. I've done my research and found that the piggyback solution that runs my car is sufficient enough for my power goals. Ill be at 300-350whp next week, and the SMT6 has no problem running the car at that power output, and thats without any CEL's.
Old Apr 18, 2007 | 03:53 PM
Witt's Avatar
The PCM isn't the only computer contained in the car. Without getting too far into it, swapping PCMs would basically cutoff communication to the Body Control Module, gauge clusters, etc. The computers talk to each other over a network using a specific protocol (language). The two PCMs use two different protocols, therefor it would not work.
There are other problems as well, such as the crank sensors not being compatible and the ignition systems being different.
Old Apr 20, 2007 | 04:58 PM
Roadrunner's Avatar
call gmpp, thats my reccommendation. if anything else gm is possible to make it work, they'll know.
Old Apr 21, 2007 | 10:55 PM
Halfcent's Avatar
I'm old school
That's won't work. GMPP will tell you nothing. And who and how exactly is he supposed to call at GMPP?
Simply put, an ECM swap is not an option.
Old Apr 22, 2007 | 12:53 AM
Witt's Avatar
You would be gaining the downsides of running a standalone on an electronic throttle car along with the limits of a stock PCM.
If you can handle getting around the comforts of having a BCM/airbag computer/power steering/etc. then just go straight standalone imo.
Old Apr 22, 2007 | 03:23 PM
TCarter's Avatar
now now guys, your giving him all false info....
instead of saying: "its not possible" you should be saying: "your wallets not deep enough"...
ANYTHING can be done with enough money and time (and alot of modification).
However, I think an ECU swap would prove to be stupid. you'd have to swap out everything....new wiring, new sensors, new ecu, new gauges, new....everything.
however, if you dont mind losing ALOT of convinience items, (DIC, Radio, Power Locks, etc) then you can disable everything, and do the swap.....but nothing will work...at all.not even your engine.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
