ZZP fitment problem
Old Jun 26, 2007 | 04:18 PM
danedecks's Avatar
ZZP fitment problem
I just am in the process of installing the ZZP mid-length header and downpipe with highflow cat. and I have noticed that the O2 censor that pulgs up to the downpipe does not reach. Should I cut it and splice a wire? Or can I order a longer O2 censor wire from somewhere?
Old Jun 26, 2007 | 05:56 PM
SSpartan's Avatar
ZZP header
bump out of curiosity.
Besides the O2 sensor how is the fitment?
what configuration did you get. (ie what size, or coating)
i was just abot to purchase this exact combo.
let me know eveything that you think about it.
Old Jun 26, 2007 | 05:59 PM
Try2k's Avatar
I just bought this and received this combo, its sitting in my garage... Keep us updated - it will be about a week before I will get around to installing it.
Old Jun 26, 2007 | 06:31 PM
danedecks's Avatar
I got zzp header 2.5 bolt-on with ceramic coating and the 2.5 bolt-on downpipe with magnaflow cat.
It all bolted up to my corsa cat with no problems and the O2 censor pluged into the header, but the bakk O2 censor does not reach the downpipe.
what should I do?
Old Jun 26, 2007 | 07:27 PM
Try2k's Avatar
Hmmm... thats the EXACT setup I ordered, even have the corsa catback lol... Did you get a upper gasket with it? I only got a lower gasket and one for the catback.
Old Jun 27, 2007 | 10:44 AM
danedecks's Avatar
it came with 3 gaskets. The one for between the block and header, one between the header and dp, and one between the dp and cat.
Old Jun 27, 2007 | 10:47 AM
BriantheLion26's Avatar
I just ordered the downpipe. I hope the sensor reaches. How short does it look it is? Isnt the o2 sensor in pretty much the same location as the stock downpipe?
Old Jun 27, 2007 | 10:50 AM
Z Speed's Avatar
I have the cat less down pipe and dont have any problems with o2 sensor fitment issues when i had my cat sensor...... now i installed my wideband in the same spot with no troubles other then it being a tight fit
Old Jun 29, 2007 | 06:21 AM
Try2k's Avatar
Well I got around to installation today, sensor doesn't reach... Guess I now am looking into a solution for this. I have it plugged right now and am getting tired of the CEL
Old Jun 29, 2007 | 06:50 PM
danedecks's Avatar
I took my o2 sensor to a local tuner shop and they add like 11 inches to it.
my CEL has not turned on yet.
I do have a leek between the header and downpipe. That piece of **** paper gasket blew. now ZZP is sending me a metal one.
but until then my car sounds like a rice burner.
Old Jun 29, 2007 | 07:30 PM
scotts2.0's Avatar
I just bought a new sensor from Advance auto parts. Fit perfect.
Old Jun 29, 2007 | 07:35 PM
Brian MP5T's Avatar
So you decided to remove one of the two O2 sensors that hook to the ECU? And replace it with a WBO2..
Did you send a signal to where the Second O2 was hooked up? (Or is it Disconnected)
Oct 21, 2015 11:57 PM
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
