Don't go 215/60 16" on your SS
Old Nov 19, 2005 | 01:12 AM
Zonomar's Avatar
Got snows this size and found the rubber rubs on some plastic inside the wheel well.
Happens only when turning semi hard or breaking/turning.
Getting 205/60 on the 16 steel rims on Monday.
Old Nov 19, 2005 | 03:01 AM
wikkymaster's Avatar
i dont see how it would be the width of the tire, but the 60 profile seems too tall for 16's considering my stock ones are 15's with 50 series
Old Nov 19, 2005 | 06:51 PM
Erod's Avatar
Moved to new Wheel & Tire forum.
yah!
Old Nov 19, 2005 | 10:45 PM
alleycat58's Avatar
60 series is fine, I have it on the SS right now. I'm guessing the diameter is too big on the 215/60s (which is funny, that's what TireRack recommends). 205/60-R16 is almost identical to the stock 215/45-R18 diameter.
Old Nov 19, 2005 | 10:55 PM
dimeo09's Avatar
ive been driving on my 215 60 16's for 2 weeks now... no problems!
Old Nov 19, 2005 | 11:23 PM
Zonomar's Avatar
It is worse on the passenger side front, turning right under breaking.
Definately the rubber, not a mark on the inside of the wheel.
Old Nov 20, 2005 | 12:59 AM
beerbaron105's Avatar
i have 215/55/16, fits like a dream, its .2 inches smaller in overall diameter then a stock tire, i could see a 60 series being slightly taller then stock.
Old Nov 21, 2005 | 02:37 PM
hardtocope's Avatar
you might have the wrong offset wheels on your car causing this rubbing problem.....
Old Nov 21, 2005 | 09:06 PM
05YELLOWSS's Avatar
I don't even have rub and I run 255/50/16 BFG G-force drag radials, them things are WIDE!!! I also had to try 3 sets of wheels for the right offset and I still don't know what it is I just tried til I got one that worked
Old Nov 21, 2005 | 09:16 PM
Mikecobalt's Avatar
My dealer sold me 205 55 R16 for mine, did they screw up I seem to be the only one with this size of tire on my steelies...
Old Nov 21, 2005 | 11:09 PM
Zonomar's Avatar
Rubbing is gone now with the 205/60 16s.
Seems to be the correct steel wheel - only 1 listed to fit on the computer at Tirecraft. Not a lot of room in the front between them and the calipers, plenty in the back.
205/55 should be fine - just a bit smaller diam.
Old Nov 21, 2005 | 11:39 PM
kissmySS's Avatar
well this is good now im really confused....do the 215 60 16 Fit? or should i go lower im getting them this week so kinda like to know what i should get, im going with the dunlop graphic d2s for about 90 a tire so cant beat that deallll......
________________________
05 Black SS - Red Inserts
**Airbox Mod** going bye bye..winter sucks!!
Old Nov 22, 2005 | 01:22 AM
Zonomar's Avatar
Get 205 like most people did, just to be safe (even if 215 did fit on a car or two - 205's should for sure).
Old Nov 24, 2005 | 08:03 PM
Jmc007's Avatar
No problem Mike; they are just three quarter of an inch smaller in diameter than your stock pirellis, and also are only 3% smaller for the circumference.
Old Nov 24, 2005 | 08:04 PM
Mikecobalt's Avatar
Thanks, I went back to the dealer to be sure and it was the size on their chart so I'm ok
Old Nov 24, 2005 | 08:18 PM
p7x's Avatar
p7x
I used 1010tire tech section tire comparison, using this you can calculate the closest tire diameter to the original, personally went with 205/60/16's because closest to the original size and you want a thinner tire when on snow and ice because increase in pressure to area ratio.
1010tire
205/60R16 - Diameter Difference: 0.28%
205/55R16 - Diameter Difference: 2.89%
215/60R16 - Diameter Difference: 2.07%
215/55R16 - Diameter Difference: 1.18%
up to 3% difference is ok
Old Dec 7, 2005 | 11:51 AM
fulltruth's Avatar
Zonobar, what did you do with the tires that didn't fit? I'm in the same predicament and it looks like I'm gonna lose a lot of money from it.
Old Dec 8, 2005 | 12:50 AM
Zonomar's Avatar
Tirecraft swapped them for ones that fit - since they sized them originally.
Old Dec 8, 2005 | 01:11 AM
CobaltSS422's Avatar
I bought Dunlop Graspic DS-2's for my car and they are great. Tire Rack said 205/60-16 and they fit fine. No rubbing at all
Old Dec 8, 2005 | 10:08 AM
Darksun's Avatar
is the offset what they mean when they say the wheel is 16x6.5
Old Dec 8, 2005 | 10:23 AM
05vicredSS's Avatar
how about 17in rims on the SS? what size tire is needed then to be at almost stock 18in diameter?
Old Dec 15, 2005 | 08:09 PM
fulltruth's Avatar
For tire size info, to www.1010tires.com/TireSizeCalculator.asp (got this from google).
I'm keeping my oversize tires because I figure TireRack won't exchange them. Here's why: in order to get the 16" 5-110 tires to show up, I had to select a Saab 9-3. So I wasn't using their recommended tire size for the Cobalt. Even if they had exchanged them, it would've cost me $40 shipping plus $90 for install.
I asked my dad about the rubbing, and he said it wasn't going to cause a blowout or anything. The difference in radius is only 1/4", and a lot of that will wear off thru the season. Plus it only rubs when I'm braking and doing a hard turn -- when the car is leaning on one corner. This only happens a few times per week. So they're staying.
Now I just need to get my speedo adjusted...
Old Dec 15, 2005 | 09:11 PM
05_Blue_B10WN_SS's Avatar
Do a few smokey burnouts, you'll be fine.
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
