Need a ECU
Need a ECU
looking for a ecu for a 2.4L G5 GT as i want to keep the original ECU stock
I plan to get a Vector tune and see they sell one for 200.00. Is this a good price for a ECU or is there a place to get a user one?
i could be wrong, but logic tells me that since the 2.2 ECU's are untunable since noones unlocked them yet, you would need a 2.4 ECU
either way, why not just stick with a gt ECU to make sure there are no mistakes?
I was gonna do that and I still have the other one. It took my flash, but the fuel enable code did not match and my car would not start.
I still have the ECM if you still want it though. I'm not gonna need it.
i dont know about the 2.4 but i remember someone trying to tune a redline in phx and using the ss/sc tune and the car was dead( no response) didnt start ot even fire
i don't know if this helps but i know there is a process that requires a tech2 to reprogram the ECU to a new car. its takes like half an hour. its kinda the same thing as if you were to replace the motor with a completely new one. i dunno just my 2 cents.
I was told had it been a virgin ECM it would have worked, but because it was used it had the other cars fuel enable signal on it.
Has anyone got a used ECM to work on their car? Maybe we just didn't take the right steps?
So vector must be using a virgin ECM then, case they ship you an ecu and you give them yours back. So with this said they are doing it from the vin number you give then during the order.
Can someone confirm that a used or a virgin ECU is needed?
vector does not use virgin ECM's......I have one and it was not new.....
any ECM with the same part number can be reflashed to all new specs.
never heard of certain codes still being in after a reflashed computer ??????
Twincharged
May 1, 2012 12:46 AM
