Need a ECU
Old Dec 24, 2007 | 10:21 PM
rcmpayne's Avatar
Need a ECU
looking for a ecu for a 2.4L G5 GT as i want to keep the original ECU stock
I plan to get a Vector tune and see they sell one for 200.00. Is this a good price for a ECU or is there a place to get a user one?
Old Dec 24, 2007 | 11:17 PM
mike25's Avatar
el junko yardo
Old Dec 26, 2007 | 06:41 PM
rcmpayne's Avatar
if i go to the junk yard do i have to get a ecu from a 2.4 G5 GT or can i get any ecu from any balt?
Old Dec 26, 2007 | 06:45 PM
njg5gt's Avatar
youll have to get an ecu from a gt or an ss
Old Dec 26, 2007 | 08:21 PM
Renesis's Avatar
I was told they were all the same, even other GM cars used the same physical ECU and it didn't matter since it'd get flashed..
Old Dec 27, 2007 | 12:13 AM
njg5gt's Avatar
i could be wrong, but logic tells me that since the 2.2 ECU's are untunable since noones unlocked them yet, you would need a 2.4 ECU
either way, why not just stick with a gt ECU to make sure there are no mistakes?
Old Dec 27, 2007 | 12:16 AM
Red2.4SS's Avatar
I don't think it will work. You will have to get a brand new blank ECM.
I was gonna do that and I still have the other one. It took my flash, but the fuel enable code did not match and my car would not start.
I still have the ECM if you still want it though. I'm not gonna need it.
Old Dec 27, 2007 | 12:40 AM
BLK SS/SC's Avatar
i dont know about the 2.4 but i remember someone trying to tune a redline in phx and using the ss/sc tune and the car was dead( no response) didnt start ot even fire
Old Dec 27, 2007 | 12:44 AM
Red2.4SS's Avatar
The ECM must have the same service number or else it is not the same.
Old Dec 27, 2007 | 12:50 AM
outtamymind's Avatar
i don't know if this helps but i know there is a process that requires a tech2 to reprogram the ECU to a new car. its takes like half an hour. its kinda the same thing as if you were to replace the motor with a completely new one. i dunno just my 2 cents.
Old Dec 27, 2007 | 12:54 AM
Red2.4SS's Avatar
I did that with the used ECM I bought and the ECM took the new program for my car and we used my vin, but when I went to start it I got security codes and the code was for the fuel enable signal from the new ECM did not match what the BCM was looking for.
I was told had it been a virgin ECM it would have worked, but because it was used it had the other cars fuel enable signal on it.
Has anyone got a used ECM to work on their car? Maybe we just didn't take the right steps?
Old Dec 27, 2007 | 09:28 AM
rcmpayne's Avatar
So vector must be using a virgin ECM then, case they ship you an ecu and you give them yours back. So with this said they are doing it from the vin number you give then during the order.
Can someone confirm that a used or a virgin ECU is needed?
Old Jan 1, 2008 | 08:51 AM
Cherry GT's Avatar
vector does not use virgin ECM's......I have one and it was not new.....
any ECM with the same part number can be reflashed to all new specs.
never heard of certain codes still being in after a reflashed computer ??????
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
toysareforboys
Nov 17, 2015 05:22 AM
Barkleyj605
Oct 24, 2015 12:07 AM
Twincharged
May 1, 2012 12:46 AM
celicacobalt
Mar 23, 2006 12:32 PM
