maybe a dumb question but...
Old Jan 20, 2005 | 11:23 AM
cdelong's Avatar
can u put a BOV on the supercharger on the colbalt? a friend of mine said u can...maybe sumone would know more than him or I? thanks for the help
Old Jan 20, 2005 | 01:25 PM
Zefhix's Avatar
Alot of the high compression supercharged cars have blow off valves to prevent an intake explosion...not sure about the cobalt.
Old Jan 20, 2005 | 01:32 PM
cdelong's Avatar
is there anyway I can find out? mabye contact my dealer or summin?
Old Jan 20, 2005 | 01:50 PM
DEI99662's Avatar
Or try contacting a vendor that is going to make aftermarket parts for the Cobalt.
Old Jan 20, 2005 | 03:09 PM
DeuceDeuce41's Avatar
My personal favorite.. I put this one on my buddy's 240sx with the SR20 swap...
http://www.turboxs.com/BOV%20Type%20H-RFL.htm
Mmmmmmmmmm... Loud.
Old Jan 21, 2005 | 12:20 PM
cdelong's Avatar
yea,like I said it maybe a dumb question...I relooked thru sum older threads and the specs were out...from wut I read on the posts and thru reasarching roots type superchargers can't not have a aftermarket BOV it already has a internal BOV that is currently in use....oh well...that's cool tho
Old Jan 21, 2005 | 05:30 PM
EvenStar's Avatar
Well by internal BOV they mean a wastegate. I don't believe supercharged cars have an area for mounting a BOV per se. All forced induction has a wastegate in some kind (and turbos can mount BOV's over the wastegate basically to release pressure faster, and make a cool sound) It doesnt improve performance but it does help either the s/c or t/c cool down faster, the release of pressure (usually at a shift point) helps alleviate the s/c or turbo so its not CONSTANTLY heated (constantly blowing that is). It just forces excess air outwards to release pressure, the basic jist. Plus it makes a cool sound! I want to get a BOV if I decide on getting PSI-FI's twincharging kit.
Old Jan 21, 2005 | 08:13 PM
Jase's Avatar
I know RSMRACING has BOVs for superchargers but i dont think they are using a roots type supercharger.
I looked on their site a while back (rsmracing.com) and saw tonnes of BOV
but again, not sure about the M62
Old Mar 11, 2005 | 11:58 PM
ircmaxell's Avatar
ummmmmmmmm.... A wastegate is an exhaust bypass in a turbo system to limit the pressure produced. Since a S/C is belt driven, there is no way of doing this (for the most part). A BOV is used to prevent a spike in pressure when the throttle is snapped shut. If one is not used, AND the pressure device (turbo OR S/C) is BEFORE the throttle blades, snapping the throttle closed will cause a pressure surge that can damage the pressure device. A BOV is used to release that pressure spike...
Old Mar 12, 2005 | 07:37 AM
Tooleman's Avatar
blown cars have a blow off valve, but it vents back into the intake.. something about drivabilty or something..
Old Mar 12, 2005 | 01:30 PM
b-spot's Avatar
Thats called a diverter valve and is used instead of a BOV
Old Mar 12, 2005 | 09:33 PM
ircmaxell's Avatar
Very good! It is used on engines with MAF sensors, so that the computer doesn't think the air went in, when it actually didn't...
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
