Brembo calipers pin issue
My wife religiously takes her 2010 SS to the dealer for service. For some reason the monkey working on the car tried removing the pins holding the pads in so he could remove the rotor to inspect the CV shafts.
Brake pads are all new 13 months ago and no anti seize was used. The monkey used a big hammer to mushroom the pins and then a chisel on the step in the middle of the pin which bent the pin.
Just so I am 100% aware the pins are held in by the spring clip correct? Not threaded or anything else? I am so angry at the moment I want to kill. I want to make sure I know it is just a little corrosion seizing them in before I do anything.
Thanks in advance.
Thanks in advance.
DANRICKARD
10-01-2015 12:08 AM
