Anyone have experience running a OZ Ultraleggera 8.5x18 et 35 on a LNF?
Old 05-28-2015, 12:24 PM
Biohazd's Avatar
A guy is selling a set of OZ Ultraleggeras but are 8.5 and 35 offset. I want to pull the trigger on them but worried that I will have rubbing issues and won't be able to run a decent sized tire. I'm currently on SSC springs so the car is lowered a lil bit. The calculators have them almost out 2 cm and only inboard by 4mm.
Old 05-28-2015, 12:42 PM
northvibe's Avatar
Aren't those the only oz ultra's that fit the SS? I have black ones..they fit but the tire rubs when my suspension compresses. I'm on pedders w/ blown out shocks/struts. so it is pretty low. I'm going to be going to new oem suspension and yyz springs.
Old 05-28-2015, 12:53 PM
Biohazd's Avatar
Yeah the 18X8 OZ's that you have are 38 offset. I had rubbing issues with my PF01's with 235/40/18 with worn out pedders coilovers so going to a slightly wider wheel and same tire has me leery of buying them.
Old 05-28-2015, 01:22 PM
northvibe's Avatar
Well I was going to go 17x9 but no one makes fender flares, so they'd rub BAD. I'm going to stick with the 18x8 oz's, I wasn't aware of 18x8.5's though. Where they custom drilled to fit the SS? If you swap to new suspension you may be able to keep the rubbing to a minimum but ya, it will rub.
I need to roll my fenders....BAD. Last time to CED I had to get footballs for the rear as the fender was taking chunks of tire, to make it home.
Old 05-28-2015, 01:46 PM
northvibe's Avatar
I think my ultras are 8.5 inch wide....but I can't remember.... stock is 8 wide
EDIT:
Merp. I bought my ultras YEARS ago off a saab guy, so I bet they are the 18x8's. I was not aware they started making 18x8.5 in our bolt pattern.
Old 06-05-2015, 05:14 PM
Supporting Vendor
doc@tirerack's Avatar
I'd plan to do a fender lip roll for the 8.5 wide / ET35, but even after that you may rub a little if the car bottoms out.... it is more hassle that it would be worth for a daily driver IMO
Old 06-05-2015, 05:32 PM
stock wheels are 18x7.5
u can roll your fenders to help with the wheel sitting a little farther out from stock or even your pf01s
u cant just base the wheels off the numbers when u have brembos
rubbing is life hahah
18x9.5 on my cobalt hehe
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
goaliemo
09-28-2015 01:37 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: Anyone have experience running a OZ Ultraleggera 8.5x18 et 35 on a LNF?
