Bnr k04-gt28
Old Oct 1, 2010 | 12:22 PM
  #101
PrincessTurbo's Avatar
Originally Posted by cubaniche
Everyone knows this. But the price is too high for the minimal gains. To re-iterate, BNR is taking a k04, gutting it, and then replace the full internals(intake and exhaust wheels, bearing and shaft) whith those of a GT28. Essentially its a GT28 in the form of a a k04.
We all know that testing is required and all that jazz but this guy has a great track record doing this for years on other vehicles, successfully. The mazda guys love him and their k04 is almost the same as ours.
Cant wait!
This isn't even close to what BTF did , the gains will make the btf wheel upgrade look like a joke
3 stages. 2860 stock compressor housing, 2860 upgraded compressor housing/actuator, and the 2871 with upgraded compressor housing and actuator. I haven't gotten to the point of prices just yet. Just making sure all machine work is done properly before I get too far involved.
400 BHP shouldn't be a problem. I am not using the K04 turbine wheel so that won't be a restriction.
Word through the grape vine is around 1250 for it ... not too bad for another hundred horses or so.
We gotta see numbers before we buy.. Already recommended it.
Old Oct 1, 2010 | 12:30 PM
  #102
elecblue06's Avatar
basically it would be the price of a new GT28 turbo.. considering it would be PnP outside of needing a BOV thats not bad
Old Oct 1, 2010 | 01:23 PM
  #103
HHRSSouth's Avatar
Please don't white wash all forums this way.
I am admin on a forum that is nothing like this - then again we also clearly state that we're user supported, and no one is profiting of the site either... we don't even have advertisements(!)
If you don't like the forum you're on (which ever one that might be), by all meants find another one ... lnf performance maybe?
FYI: I just tried, and it looks like the BNR site has server issues at the moment.
I know that I would be interested in something like this... especially since it's technically not an aftermarket part
(it helps that I too have a spare turbo here)
I'm glad to read that Brian has replied, and that HHRsouth is on the 'to be notified' list...
I have been trying to keep up with (and posting) about possible turbocharger upgrades from around the LNF community for awhile now (some panned out, some didn't). Along with contacting manufacturers like APR about K04 upgrades.
So far every single K04 upgrade or hybrid for the factory K04 has started with posts in the Kappa platform forums, the K04+, TD05 hybrid along with a few others variations, including BNR Racing's idea.
I'm also the one that posted about the new Mitsubishi LNF Regal Turbocharger as I'm the one that actually physically has one in hand. It is a LNF turbo made by Mitsubishi, its uses the LNF flange. By the way my original thread on it ended up in the resulting of other members having the insight to find a bolt on Forge bov for the BW K04 (great job to those guys).
BTF (Bald Turbo Freak) has gotten back in touch with me and told me it was the new 2011 Regal LNF turbo also, now if you know more about Turbo chargers for the LNF platform then him, please let the rest of us know.
Some people just want everything handed to them without doing anything and then bitch when they get it. You should just be lucky other members of this forum are doing the leg work for you so you can enjoy upgrades.
Old Oct 1, 2010 | 01:29 PM
  #104
Terminator2's Avatar
Originally Posted by 40rty
Around that yes. BTF or Rick crunched some numbers and got 41lbs a min with his upgrade, so BNR's GT2871r upgrade would be more like 44-45lbs a min I would guess.
Max flow should be right around 47 lbs/min at 26psi or so.
Old Oct 1, 2010 | 01:32 PM
  #105
slowbalt84's Avatar
i sure hope this works out. Has anyone else ever noticed that anyone that has put a different turbo on the stock manifold has had lag issues? I honestly don't think this stock exhaust manifold can flow enough to make good numbers down low. im hoping since this is kind of a stock turbo it will be better.
Old Oct 1, 2010 | 01:35 PM
  #106
HHRSSouth's Avatar
Maybe we can get BADMAB to make a new manifold for us? In his post he didn't seem to think there would be a good market for it.
Old Oct 1, 2010 | 01:40 PM
  #107
slowbalt84's Avatar
its just some food for thought. I have a precision 50 trim and it takes FOREVER to spool. I have done research and Badbaltguy, FF ACE, PT5457, and Boostking were all on stock manifold but slightly bigger turbo and they just wont spool up. But when switched to an aftermarket manifold they suddendly spool up like they're supposed to. I have done everything to get this turbo to spool faster from tuning to shortening the wastegate rod as short as it will go.
Old Oct 1, 2010 | 01:42 PM
  #108
slowbalt84's Avatar
so don't be suprised if you guys buy this and it wont spool up until about 3000 RPMs and get full boost at about 4500 RPMs. My setup is easily at 400whp but anything less than 4000 RPMs and a Prius could probably walk me lol
Old Oct 1, 2010 | 01:47 PM
  #109
HHRSSouth's Avatar
At least you get good fuel economy around town
Old Oct 1, 2010 | 02:06 PM
  #110
elecblue06's Avatar
you think it would be because of the twin scroll feature? then being used on a non twin scroll turbo?
Old Oct 1, 2010 | 02:08 PM
  #111
elecblue06's Avatar
also theres someone i know of with a 3076 on their car .. and i think a modded stock manifold and from what i've heard it had no problems spooling
Old Oct 1, 2010 | 02:59 PM
  #112
cubaniche's Avatar
I think the 2860 and 2871 both with upgraded compressor housings would need aftermarket BOV but the 2860 in stock housing keeps stock BPV from what I understand, eliminating the need for a BOV.
I guess it all depends what you are trying to achieve. Im not sure if I want the slightly slower spool and more top end of the 2871, while also needing a BOV, or the faster spool and slightly less top end of the 2860, keeping the stock BPV and not having to mess with a BOV.
Decisions decisions....
Old Oct 1, 2010 | 03:04 PM
  #113
elecblue06's Avatar
that would all depend on dyno numbers ya know .. if you can get 360 whp with the 2860 std but 380 with the 2860+ but then can get 450 with the 2871 a little slower spool would be worth it for the small price difference IMO lol
Old Oct 1, 2010 | 03:17 PM
  #114
cubaniche's Avatar
My real nag about going '+' is having to get a BOV and having to mess with that. I know that more power requires more modding, just not sure if I want the mess thats associated with putting a BOV on the LNF.
Old Oct 1, 2010 | 03:28 PM
  #115
elecblue06's Avatar
yea if you want big power you'll be doing that anyway though
Old Oct 1, 2010 | 03:29 PM
  #116
Valve springs and wind that bitch to 7500 I loose so much efficiency up top and that is where I tend to be falling off .. I want it to be efficient till almost 7k at least ..
Old Oct 1, 2010 | 03:47 PM
  #117
You need some intake and exhaust cam tuning. You would spool about 700-800 RPMs sooner.
Old Oct 1, 2010 | 03:51 PM
  #118
Originally Posted by 08SSTCRD
No, they really aren't efficient or long lasting. You obviously have no experience servicing turbocharged engines. Mitsubishi has tons of problems with their turbos, most common being bad turbo seals which cause oil burning. Evos go through oil faster than they go through fuel.
GM chose Borg Warner for the SS LNF for a reason, they are one of the top quality turbo suppliers in the world. Borg Warner is a German company, and quality is number 1. Mitsubishi has quality listed somewhere around job 1000, which comes somewhere after make lots of money selling junk products to gullible idiots.
Turbo failures of the K04 are rare, you will see a huge spike in turbo failures when these new Mitsu turbos come out though, unless they have improved the quality of them somehow.
This! I have put my BW K-04 through hell and it has zero shaft play and uses not a drop of oil.
Old Oct 1, 2010 | 04:03 PM
  #119
Yeah I beat the **** out of mine too .. sad but true , it won't die , even at 6k ft with the turbo working even harder.. Figured I would have cooked it by now but I can't break it. ( If it breaks it gives me an excuse to replace it with better stuff
So in a sense I kind of want it to fail but it wont .. Damn German turbo and your superior build quality
Old Oct 1, 2010 | 04:11 PM
  #120
slowbalt84's Avatar
this is exactly what my tuner said
Old Oct 1, 2010 | 04:33 PM
  #121
elecblue06's Avatar
using BNR should have the same twin scoll exhaust setup so that should be helpful
Old Oct 1, 2010 | 06:05 PM
  #122
slowbalt84's Avatar
exactly. so we'll find out if the problem is that the stock manifold just doesnt flow OR if it being setup for a twin scroll turbo makes it now work very well with a single scroll turbo
Old Oct 1, 2010 | 11:31 PM
  #123
knickick's Avatar
Hi RoadconeTuning. We have the same idea for the similar to liekt he FP White for the evos.
Old Oct 2, 2010 | 06:34 AM
  #124
jimbos'ss's Avatar
ok so whats the pricing on the gt2871 version? $1300? if so i'm about to start saving now.
Old Oct 2, 2010 | 09:10 AM
  #125
40rty's Avatar
I'm guessing that even with a twin scroll setup, this will probably be hitting full boost at 3200-37. Also, you guys are going to be losing some torque too. That is my guess. 400whp is a possibility before running into the DI fueling problem, even if Vince from Trifecta has found a work around. Someone needs to unlock that **** already. Guys i think I would be happy with 400whp if I still had my SS/TC. What is the point of more in a FWD car. Think I should ditch the GLi and get a Sky Redline with this upgrade????
