Bnr k04-gt28
Old Oct 8, 2010 | 08:22 AM
  #176
jimbos'ss's Avatar
Originally Posted by 40rty
I wouldn't give up yet, lets just see how it runs first on a dyno. That Twin scroll might make up for it, you never know.
probably not, but we shall see.
Old Oct 8, 2010 | 09:03 AM
  #177
HHRSSouth's Avatar
I highly doubt BNR is going to invest all the time in research, tooling, jigs and setting up CNC programs for our particular K04 to have it fail. Don't forget hes been converting factory turbos for other platforms as well.
Old Oct 8, 2010 | 09:55 AM
  #178
Terminator2's Avatar
Meh no lag on out factory K-04s so I am not that worried. I think the cost to benefit ratio will be nice on this setup. I am thinking it should be able to hit 400 whp at 24 psi.
Old Oct 8, 2010 | 09:58 AM
  #179
cubaniche's Avatar
Which wheel are you referring to, the 2871?
Old Oct 8, 2010 | 11:46 AM
  #180
PrincessTurbo's Avatar
yeah because I am doing this option pretty sure .. So you will have multiple people to tune with and get the bugs worked out if you wanna go in on it together ...
I don't really like aftermarket BOV's for the sound effects so what wheel do you think will hit 400 , thats the one I want .
Old Oct 8, 2010 | 11:54 AM
  #181
cubaniche's Avatar
Se we ARE talking about the 2860 stage1 right? lol
Cause Im in the same boat as you. Im not going to mess with BOV and MAF relocate, but Im under the impression that 360whp would be safe and efficient on the 2860.
Old Oct 8, 2010 | 12:20 PM
  #182
I would like to see how much difference in makes on your car for sure. I would go with the 2871 option because it should get you to 400whp.
Old Oct 8, 2010 | 01:05 PM
  #183
tglems's Avatar
If you go 2871 does that mean new clutch? What other supporting mods would you need? I have full bolt ons at this point, but if I were to do this I would want to do it at minimum cost...
Old Oct 8, 2010 | 01:28 PM
  #184
I would think if you wnt conservative with the boost delivery to avoid shocking the clutch the stocker should hold.
Old Oct 8, 2010 | 02:23 PM
  #185
BLKBOLTSS's Avatar
I'm curious how these turbo "upgrades" would fair with a fully bolted Balt. And maybe one that is fully bolted with a good clutch and some pistons. I wanna hit the low 400s at the wheel and this seems like the best way to go about it.
Old Oct 8, 2010 | 02:41 PM
  #186
jimbos'ss's Avatar
it should hit 45lb/min at roughly 2.25 pr in a perfect world, so depending on elevation above sea level it could be as low as 19 psi to hit 400hp. i'm thinking average for 400whp will be close to 22psi.
Old Oct 8, 2010 | 02:48 PM
  #187
cubaniche's Avatar
Then you would want the 2871, full bolt-ons and a good tune and clutch. Not too strong a clutch cause you want it to slip a little like the stocker does so you dont blow your tranny like others have.
You just described my balt. Full-bolt-ons and pistons. Im looking at the 2860 and maybe 360whp. Thats all I want. Thats enough power for me to have fun with it still as a DD and some time at the track too
Old Oct 8, 2010 | 03:21 PM
  #188
Taking into account that there will be an efficiency reduction associated with putting those larger wheels in our housing, albeit reconfigured, I am expecting it to be 5% or so less efficient than a regular GT2971R.
Old Oct 8, 2010 | 03:24 PM
  #189
BLKBOLTSS's Avatar
I don't have the pistons or the clutch yet but those are my next two upgrades. I'm just tryin to figure out the wat type of power we are lookin at.
Old Oct 8, 2010 | 03:50 PM
  #190
jb09ss's Avatar
Yes, should be a tad less efficient than a "real" gt2871, but still a major upgrade over the stock k04. As you said, the cost to benefit ratio of this upgrade will be good and I am 100% for that, I bought a cobalt after-all! I can't bring myself to spend 25% or more of my car value for a turbo upgrade!
Old Oct 8, 2010 | 04:03 PM
  #191
elecblue06's Avatar
yea the advantage of these turbos is you'll need to spend like 1750 and your done lol
turbo, bov setup (charge piping) and tune and your done lol
Old Oct 8, 2010 | 04:12 PM
  #192
FF_ace's Avatar
I just need the turbo and the bov
Old Oct 8, 2010 | 11:39 PM
  #193
elecblue06's Avatar
i'd just needz turdbo and **** to go with it .. i have tunez and bov lol so that means i'd need all the expensive parts lol
Old Oct 10, 2010 | 09:40 PM
  #194
LOL you too huh ???
I might make a vid tutorial how to remove and install the stock turbo..
It is still over some peoples heads but with a video maybe every one would have the confidence to yank it out and send it on over to BNR...
Old Oct 10, 2010 | 10:47 PM
  #195
40rty's Avatar
^^^ I think that you should do it.
Old Oct 11, 2010 | 10:42 AM
  #196
redcomet303's Avatar
So I'm thinking about this for my sky. It will get great to see some dyno numbers. I might be going for the stage 1 just to leave everything stock except for the turbo. Would be nice with a trifecta hide a tune.
Old Oct 11, 2010 | 01:05 PM
  #197
Its the big wheel or bust for me ... I don't see the smallest wheel adding more than 20 WHP honestly ...
Old Oct 11, 2010 | 01:50 PM
  #198
dandaman15's Avatar
The 2860 in the stock housing (Stage 1) would probably be maxed at 375hp, as long as you have intake, intercooler upgrade, and full exhaust. It also depends on elevation and other factors but 380-400 is perfectly feasible. Ive heard of people pushing disco potatoes to 26psi for years with no problems. Thats still a gain of 65hp over a TC with full bolt ons and Trifecta tune. That is a little bit optimistic but the Stage 1 will add way more than 20whp, probably more than 40whp honestly.
Old Oct 11, 2010 | 02:22 PM
  #199
Ok so I am no expert and I'll be very optimistic but what are you thinking the Stage3 2871 would do ?
Old Oct 11, 2010 | 02:44 PM
  #200
fakameanrepresent's Avatar
LOL you too huh ???
if you do that, and if i can get somwhere with 350 ish whp with this modified stock turbo. i will be down to buy it.
