09 Cobalt SS LNF Build
Old Sep 24, 2022 | 07:25 AM
Colby2211's Avatar
Arrow 09 Cobalt SS LNF Build
Hello all,
Im about to purchase a 09 Cobalt SS LNF. And i would like any and all insight as to what you guys would suggest as far as a build list for everything. Ive got mostly everything i think is correct in my list and i am open to anymore suggestions or changes.
The list is as follows,
Cobalt LNF/LHU Turbo Upgrade – ZZPerformance
LED Headlight Conversion Kit – ZZPerformance
ZZP Ecotec Billet Engine Mount – ZZPerformance
Outer Tie Rod - Ecotec – ZZPerformance
MOOG Front Sway Bar End Link – ZZPerformance
MOOG Sway Bar bushings for Cobalt SS – ZZPerformance
ZZPerformance Cobalt Front Sway Bar
Suspension & Brakes – ZZPerformance
Ecotec Front Trans Mount – ZZPerformance
ZZP Rotated Rear Trans Mount Gen3 – ZZPerformance
BC Racing Coilover – ZZPerformance
GM Stage 1 Sensors – ZZPerformance
LNF Downpipe Gasket – ZZPerformance
LNF/LDK Camshaft Bolt – ZZPerformance
Cloyes Ecotec Timing Chain & Guide Set – ZZPerformance
3 inch Stainless Steel Cobalt LNF Catback Exhaust – ZZPerformance
Like i said im open to any suggestions you guys may have. The car is also stock other than the porous block being replaced with a brand new LDK block from zzp.
Thanks for looking.
Old Sep 24, 2022 | 07:44 AM
slapbetcommissioner's Avatar
I guess my first question is what are your power goals? What fuel will you be running?
Old Sep 24, 2022 | 07:49 AM
Colby2211's Avatar
im not really looking for specific numbers just whatever i can make with what i got after i save up a bit more money im also gonna get forged internals.
and ill be running pump gas
Old Sep 24, 2022 | 08:04 AM
Originally Posted by Colby2211
Hello all,
It’s a great kit. But depending on your power goals it might be a bit overkill. Your going to need some more stuff to take advantage of it for sure I’ll cover that In another message.
Personally I wouldn’t run this in stock housings. Very blinding for everyone else. I would do a proper retrofit Hid or Led setup using projectors. (Retrofit source is your friend here)
Factory mount is usually more than sufficient especially with the trans mounts you listed below. However it is a nice looking piece dealers choice here.
If your tie rods aren’t busted I wouldn’t change them.
good upgrade the gm ones are garbage.
unless your factory ones are wearing out probably not necessary. (Mine we’re mint with 110k km on them.
Don’t believe this is much of an upgrade for an lnf.
makes the car rotate a little nicer in tight corners. Ottp and Powell offer a few different levels of stiffness most people go that route if they are doing auto cross. Not sure how zzp version compares.
good mod. Ottp and Powell (Powell’s original design) offer this as well.
see above. Best traction mod and trans saver out there. Helps with wheel hop.
all a mater of opinion but bc makes good quality stuff.
must have
not sure why this is on here
probably unnecessary depending how many miles are on the new engine.
good quality product.
Made some notes between products
Old Sep 24, 2022 | 08:18 AM
Things you will likely need. If your control arms still have shitty gm “voided” rear control arm bushings they tear like paper. Get some spherical ones from Powell ottp or moog (moog ones are relatively new I can’t speak to them for quality. My powell ones are one of the best mods ive done.
depending on your power goals that turbo kit may be overkill and will be a bit on the laggy side. If your looking for a solid 400-450whp you may want to look at the z54 or zzp zfr 6758. It will be more responsive than the s257 in the full turbo kit.
if your goals are well over 400whp or your planning on running e85 or a mix e47 etc. you will need fuel mods.
options include zzp s2 cams with fuel lobe upgrade. ( upgraded valve springs will be needed and suggested regardless if your getting over 400whp)
z06 mechanical fuel pump upgrade bigger injectors 5th injector and meth injection are all adders that can be combined I won’t get into detail here without knowing your power goals.
based on what you have lined up there your going to need an upgraded clutch before long. Lots of guys run the gmpp upgraded clutch it bats way out side it’s suggested weight class. There are lots of other options as well if you are planning to go big power. I e seen this hold over 500whp for years on several cars on the forums and local. (Slicks would be the killer here)
Chances are your trans won’t last long at much over 400whp some guys get lucky and driver mod helps. ( I’m on my original stock clutch and trans at close to 400whp.
your probably gonna wanna get horsepower tuners of your own and laptop as well if you don’t already have.
Colby2211's Avatar
i was looking at the tuebo upgrade kit because it listed as having the aftermarket charge pipes and intercooler from zzp which by itself is currently out of stock with just the intercooler kit. the upgrade kit also included the ecm and turbo downpipe.
Old Sep 24, 2022 | 08:20 AM
Colby2211's Avatar
i was also looking into getting hp tuners i would have to learn how to tune myself. do you have any suggestions on other places that offer aftermarket intercooler kits.
Old Sep 24, 2022 | 08:21 AM
It is a complete kit in that regard.
If you switched to one of the other turbos I mentioned you would want to add a downpipe and intercooler kit to the mix.
what are your power goals.
Old Sep 24, 2022 | 08:26 AM
if zzp is saying there intercooler kits aren’t in stock I would question weather they have a set for the turbo kits either.
might be worth emailing them if your spending that kinda $$
I would get zzp setup if I were you. Used to be several options I honestly don’t know who makes these kits if anyone else anymore.
Old Sep 24, 2022 | 08:27 AM
You can get remote tuned if you have your own HPT it involves paying someone to tune you and sending logs to them so they can make adjustments. I wouldn’t just jump in and try tuning yourself if your not experienced. Not the easiest platform for that.
Old Sep 24, 2022 | 08:28 AM
What are your power goals?
Old Sep 24, 2022 | 08:35 AM
Colby2211's Avatar
i would say 350-400 range not to picky on waht i can get with the mods im gonna go with right out of the gate
Old Sep 24, 2022 | 08:37 AM
Colby2211's Avatar
HP Tuners MPVI 3 – ZZPerformance
This is what i need correct?
i already have a laptop i can use
Old Sep 24, 2022 | 08:39 AM
Okay. That turbo kit is major overkill for those goals.
honestly get the z54 turbo
3” downpipe and zzp intercooler kit.
you won’t need fuel mods or valve springs or anything and may even get away with your stock clutch.
turbo is responsive and fun and will leave you a bit of head room if you wanna go e47 or spray meth later.
Old Sep 24, 2022 | 08:40 AM
yes that’s the ticket. And two credits to unlock your car
Old Sep 24, 2022 | 08:53 AM
Colby2211's Avatar
is the z54 direct bolt on no extras needed?
Old Sep 24, 2022 | 09:10 AM
Colby2211's Avatar
ZZP LNF Turbo PCM - Email me an HPTuners file
VIN: 1G1AP58X997174399
Year of Vehicle: 2009
Model: Cobalt SS
Transmission : Manual
Intake Option: ZZP 3.25" Intake
Turbo Option: Z54 Turbo ($25.00)
Boost Option: 1st Gear Boost Reduction
Clutch Option: Stock Clutch
Senson Option: GMS1 S Bar Sensor
Fuel Type: I run 91 Octane
Injector Options: I run Stock LNF Injectors
Configure
Model: Cobalt SS
Quantity−+
Remove
$234.99
ZZP Z54 Turbo
Quantity−+
Remove
$1,29999$1,299.99
HP Tuners MPVI 3
Credits: 2 Credits
Quantity−+
Remove
$49999$499.99
LNF Stainless Downpipe
Transmission: Manual
Quantity−+
Remove
$30499$304.99
Size: 9.86 Inches Long
Quantity−+
Remove
$2999$29.99
Quantity−+
Remove
$1399$13.99
ZZP Ecotec Rear Sway Bar
Quantity−+
Remove
$13999$139.99
Quantity−+
Remove
$9999$99.99
Ecotec Rotated Rear Trans Mount Gen3
Quantity−+
Remove
$10999$109.99
BC Racing Coilovers - Ecotec
Spring Combo: Standard 6k/6k
Quantity−+
Remove
$1,19500$1,195.00
GM Stage 1 Sensors
Quantity−+
Remove
$11499$114.99
LNF Downpipe Gasket
Quantity−+
Remove
$1299$12.99
Resonator: No Resonator
Muffler Option: Add Muffler
Quantity−+
Remove
this is the new compiled list
Old Sep 24, 2022 | 09:26 AM
It comes with everything you need to install it yes. Technically it could replace the factory one without changing any other parts. It’s just highly recommended you replace intercooler and piping and downpipe which you are getting so perfect.
Old Sep 24, 2022 | 09:33 AM
Model: Cobalt SS
Configure
Model: Cobalt SS
Quantity−+
Remove
$234.99
ZZP Z54 Turbo
Quantity−+
Remove
$1,29999$1,299.99
HP Tuners MPVI 3
Credits: 2 Credits
Quantity−+
Remove
$49999$499.99
Quantity−+
Remove
$30499$304.99
Quantity−+
Remove
$2999$29.99
Quantity−+
Remove
$1399$13.99
Quantity−+
Remove
$13999$139.99
Quantity−+
Remove
$9999$99.99
Quantity−+
Remove
$10999$109.99
Quantity−+
Remove
$1,19500$1,195.00
GM Stage 1 Sensors
Quantity−+
Remove
$11499$114.99
LNF Downpipe Gasket
Quantity−+
Remove
$1299$12.99
Quantity−+
Remove
I do believe this is a pretty complete list. The suspension stuff is optional of course but I don’t see any bad picks there.
only thing I 100% think you should get is spherical control Arm bushings. Stock ones are garbage.
powell
ottp or moog.
moog ones are relatively cheap but I have no idea about there quality or longevity. They couldn’t be worse than stock.
Old Sep 24, 2022 | 09:36 AM
You may want to get new banjo gaskets for the turbo coolant lines and a new gasket for the oil drain fitting.
and possibly a gasket for the turbo to exhaust manifold as well. You may get away with re using them but it’s a shitty thing to cheap out on and need or have leaks after.
Aside from things possibly breaking when you take them apart you shouldn’t need anything that I can think of. A couple of the remaining guys on here may want to chime in if I’m forgetting something
Old Sep 24, 2022 | 09:55 AM
Just realized the intercooler and pipes isn’t on there. But I’m assuming that’s just because it isn’t in stock?
it’s not that the stock pipes are particularly restrictive but the plastic has a tendency of splitting and the end tanks of the stock cooler are also plastic and troublesome. You could probably get away with them for a bit if you need to wait on an intercooler kit
Old Sep 24, 2022 | 10:10 AM
Colby2211's Avatar
I emailed Zzp in regards to their intercooler kit being out of stock I also added the cold air intake as well
Old Sep 24, 2022 | 10:26 AM
seems like a good choice.
Old Sep 27, 2022 | 06:57 AM
fst100's Avatar
honestly you could get close to the 350whp goal with minimal mods, such as tune, cai, upper/lower charge pipes, downpipe and engine mounts. the tune would be the biggest in gains and switch from pump gas to e47 and be able to run on stock hpfp.
Old Sep 27, 2022 | 09:52 AM
I don’t disagree. But the power band is allot better on the z54 and not pushing as much boost.
making 350whp and making power right to redline feels amazing after being on the stock turbo getting choked at 5k rpms.
Also less of the trans and clutch destroying torque. (Not that it it isn’t fun having tons of torque low in the power band.
also at that power level it’s just getting sweet so a fair bit of room to grow with the larger turbo. Especially on e47 if he were to go that route.
pdodson
Mar 3, 2016 01:11 PM
no_ss
Oct 3, 2014 12:51 PM
Canadia
Aug 11, 2014 07:14 PM
Fuzz
Feb 25, 2013 10:15 PM
joeyfingers
Sep 1, 2012 10:51 PM
