2009 SS/TC Uneven tire wear in front, non G85
I have 2600+- miles on my car and I am noticing the front drivers side tire seems to be wearing out faster than the pass side. It does not have LSD. Is this normal? I had an 03 SRT4 (didnt have LSD, either) and those wore out evenly. It doesnt seem to have excessive tq steer, never really pulls to one side or other when getting on it like you would assume it would if one side was getting most of the power.
Yeah, the on board info says they are all about 31-32psi warm, but I will check them with a gauge when I go home. As far as alignment, it tracks straight,....doesnt seem to pull one way or other.
Its possible, back when I picked up my new 04 Saturn, I found out I had uneven tire wear, right around the same mileage you have. I took it to the dealer and my alignment and camber were both slightly off, luckily they fixed it for free.
Well, since getting the superchips tune, they break loose a lot easier, so I was wondering if not having LSD was causing this uneven wear.
I just did a quick and dirty tread depth check between the fronts, the drivers side has 5mm of tread, the pass side has 6 And the rears have 7.5mm
Lol, it would be hard right turns. No more than with any other car I have owned.
If the camber or alignment was off, would there be other tell tale signs? Cupping, or uneven wear on the tire itself? The tire itself is even across the whole tread.
if it was camber alone, you'd have wear on the inside of the tire for camber that is too negative. if the camber was too positive, well you would know lol.
it could be possible to drive in a straight line without any pull while having your alignment off. you would just have to have your alignment off on the compliment tire that cancels out the pull from the first tire that was off.
I had this on my old car for a while. only way this could happen is if you were in an accident or you have someone fix the alignment without using a computer alignment tool. of course all four tires would probably wear from this.
right turns would stress the passengar side more
If you turn left, the body rolls right, right? Unloading the left tire, and stressing the right.
I did with marking off a penny, the left side had 5mm of tread, the right had 6, and the rears had 7.5mm
Im gonna go to the parts store after work and get a tread depth gauge and find out once and for all what the diff is. If its not too much I will just rotate them and call it a day.
yes but unloading the left tire with power on will cause that tire to spin in a non lsd car right? Thats pretty much the reason for lsd .....turning . In a straight line both tires should spin lsd or not .
I don't track my car, and haven't ever got on it hard enough in a corner to induce wheel spin. Only time I have tried to get them to spin has been rolling hard in first, and some times second (when it was cold here)
DANRICKARD
10-01-2015 12:08 AM
