25psi Spike on GM Tune
Old 01-21-2010, 01:40 PM
Permafried-'s Avatar
Originally Posted by Psytocrophic
I kind of have an off topic question.. Do you think having a GMS1 Trifecta or HPTuners will make your car less efficiant on the track (like autocross not drag) due to traction issues, losing control on turns ect ect? or do you think if you can maintain proper speed and know what your doing it will be even quicker?
Continue..
You'll need to practice more throttle control particularly in 2nd and 3rd gear with the increased HP/TQ comes increased wheelspin being FWD. Beyond that I can't see it as being less efficient since it gets up to speed faster and digs harder out of the corners even in the lower RPM band. This is with the GMS1 anyways; with Trifecta and HP Tuners it entirely depends how your boost is controlled and when it comes on strong, etc.
Old 01-21-2010, 03:46 PM
BYT*SS*TURBO's Avatar
25psi!!???!?!?!? You're going to have piston failure.
(Obviously sarcasm if you couldn't figure it out)
Old 01-21-2010, 04:10 PM
crypticscifer's Avatar
I say he blows the floor bolts.
Old 01-21-2010, 05:06 PM
SSlobalt's Avatar
Nah. Manifold welds, fo sho!
Old 01-21-2010, 08:21 PM
RYRO14's Avatar
Originally Posted by JPizzle
It only spikes 25psi after I clear the code: P2096 Post Catalytic Fuel Trim Bank 1 System Too Lean. And then it pulls like a raped ape at 25 psi, then I try a minute or so later, and it holds 20psi like it should....
Is this the ECU not being about to compensate for the first WOT after I clear the code (Kinda like learn down?)
Yeah the ECU knows somethings up, then you clear the code and it forgets and then compensates to prevent overspinning the turbo. Your pretty much ******* with your ECU and the turbo is paying the price lol
Old 01-21-2010, 08:33 PM
JPizzle's Avatar
Yea, that's what I'm thinking. I just hope the Hahn DP fixes this problem.
Old 07-18-2011, 10:02 AM
kebbester's Avatar
I have a 09 tc with stage 1 a k&n drop in and a forge bpv and im holding not spiking at 24-25 psi every now and then! It stops at 20psi for a sec then goes to 24 psi at wot .
Old 07-18-2011, 10:07 AM
BartSS's Avatar
Originally Posted by 80vetteL82
Yah, Ive spiked up to about 24-25psi with just a Dejon SRI.
You should dyno'd. I dont think anybody has dynod the GMS1 with that many bolt ons. Id be curious to see what it does.
I dynod mine with full boltons and the stage kit... dyno was a little gay but i got 286whp and 297tq
Old 07-18-2011, 11:18 AM
CudaJoe's Avatar
Thanks for bringing this thread back, otherwise I would have never seen it...
Old 07-18-2011, 11:20 AM
RYRO14's Avatar
Damn old thread lol
Old 07-18-2011, 11:26 AM
  #36
DoMiStIc_RuSh_06's Avatar
That's pretty close to what I got, mines down in hp a bit tho. With gms1, Kn Sri and tbe I made 271Whp & 297wtq with my car acting wonky.
Old 07-18-2011, 11:38 AM
  #37
gdubs's Avatar
I have.
Old 07-18-2011, 11:57 AM
  #38
umrdyldo's Avatar
Revivals rule.
Mine spikes 25psi when it's really hot out. NBD.
Old 07-22-2011, 10:22 AM
  #39
steven2008ss's Avatar
another revival mine spikes 23-25 in the heat too lmfao
Supercharged06SS
12-11-2022 04:47 PM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
anotherslowlnf
09-29-2015 03:52 PM
OPCrer
09-27-2015 08:11 PM
Quick Reply: 25psi Spike on GM Tune
