Any tips getting upper charge loose from turbo?
Old Apr 10, 2015 | 03:29 PM
axmonkey's Avatar
Question Any tips getting upper charge loose from turbo?
I need to do a boost leak test, so trying to get the upper charge off at the turbo.
I've got the nut on the clamp all the way out and it's loose all the way around. Disconnected the PCV line on the intake, just so I don't bust it off. I have the clip off on the plastic part of the pipe on the drivers side of the engine to give me more wiggle room. I'm tryin to pull this beast off but it's not budging. Any tips from the pros?
Thanks in advance.
Old Apr 10, 2015 | 03:31 PM
umrdyldo's Avatar
A little heat, not a lot. Hell could probably just warm it up with a test run.
Wiggle, shimmy, shake, etc. Could be careful with a flathead screwdrivers and pry it up a bit to get it started.
Old Apr 10, 2015 | 03:44 PM
kzak104's Avatar
keep ripping on it, lol, or get a 90* pick in there, irs probably melted to the turbo, ha
Old Apr 10, 2015 | 03:45 PM
umrdyldo's Avatar
Yeah a set of picks might help get started.
Old Apr 10, 2015 | 04:22 PM
tomj77's Avatar
Are u trying to pull the coupler off the turbo or are u trying to pull the upper cp from the coupler that is attached to the turbo? And what brand cp
Old Apr 10, 2015 | 04:26 PM
axmonkey's Avatar
Stock CP
Old Apr 10, 2015 | 05:45 PM
Omiotek's Avatar
Get a pick tool in there. It will come.
Old Apr 10, 2015 | 05:56 PM
exninja's Avatar
I do remember that being unduly ridiculous. Be careful with the pick though, last thing you want to do while testing for a boost leak is to cause another one!
Old Apr 10, 2015 | 08:25 PM
09outlander's Avatar
Twist and pull, if that doesn't work find a friend that is stronger than you.
Old Apr 11, 2015 | 07:40 AM
StevoElSupremo's Avatar
yep mine was glued on there pretty good, I just reamed on it and eventually it popped off
Old Apr 11, 2015 | 10:54 AM
axmonkey's Avatar
Got it! The "twist" was critical. This morning I gave it another go, tried twisting it right then left, and it finally broke lose! Pulled it and it popped right off, easy peasy.
Now to build the jig for the boost test, off to home Depot!
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
