brake question
Old Apr 11, 2015 | 08:27 PM
imperialblueSS's Avatar
brake question
I dunno if this is in the right forum but here is goes I have the R1 front drilled and slotted rotors and when I brake the steering wheel shakes and I was wondering if we could get this turned or even milled down to stop the shaking
Old Apr 11, 2015 | 09:00 PM
Superbolt's Avatar
Not sure about drilled and slotted
Old Apr 11, 2015 | 09:05 PM
Jacque8080's Avatar
Negative ghost rider. I wanted to get some slotted rotors turned and all the chain and independent shops said no. They said it is hard on their cutting bits.
I just bought a new set of solid and vented rotors.
Old Apr 11, 2015 | 09:08 PM
Ive turned 2 sets of drilled and slotted rotors but then again i did them and i could see them as to harsh for the bits but wouldnt be certain in that
Old Apr 11, 2015 | 09:27 PM
09outlander's Avatar
They can be turned, just need to take off less material per pass to help reduce wear on the bit.
Old Apr 11, 2015 | 09:35 PM
Well even if they where blanks i wouldnt go to deep either small increments its the best. Also depends on how badly warped the rotors are
Old Apr 11, 2015 | 10:24 PM
I did ask around town and one said they have a machine that can turn them while they are still on the car I dunno how that works but I might just try but I do need to get ahold of R1 and look at a set just in case they do chip a chunk out
Old Apr 11, 2015 | 10:26 PM
Yup the machine i used is called a procut is an onboard cutter really easy to use actually
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
