best pcm
best pcm
im not pulling boost which may also be a ic problem but I'm throwing a pcm fault code so i was gonna replace my factory pcm.. everything is stock on my car I'm wondering what pcm would be best to replace it with. only future modes would be bolt on
You can still tune the stock PCM for whatever bolt ons you get. So stock would be best. Stock PCM with a tune, which can/will increase boost.
Are you serious? If you use any other pcm like megasquirt or summit then it won't pass an inspection and you would need a hell of a setup to even need to think about that route. The factory pcm is tuneable.
sorry bro I'm new to this. okay so i can tune my stock if i wanted.. now if its throwing pcm fault .. should i replace it or is it possible just to have it reflashed?
thanks for your help!
thanks bro.. i think i may do the zzperformance whats your thoughts on that?
