big problems with clutch change need help
ok i had a mechanic put in a cluthmasters clutch and now my car says service traction and the abs light is on and it wont go above 0 boost please help asap
Call performance aute werks in plainfield illinois Dave will be more than happy to help you. Or look up mkriebs here on the forum he works there he can help you as well. I got my clutch done ther and have had no problems. Hope this helps
Rattlesnake Race Shop
I think that your Mechanic left something unhooked. Just a guess though. Check your ABS sensors... should be right behind the front rotors. He might have unplugged them and forgotten to plug them back in. Don't know why that would limit you to 0psi though. Have you done a proper break-in on it? That won't have an effect on how much boost you hit, I'm just making sure you aren't on mile 5 trying to boost on this new clutch.
I'm not sure how the Traction Control works though, as I don't have that on my car, nor do I have experience with it on Cobalts.
I'm betting that a sensor is disconnected though.
thanks for helping me it must have been a connector for the abs that was causing everything except the boost was from a pipe that he did not put back properly
