Bnr k04-gt28
Old Dec 8, 2010 | 10:47 PM
  #401
40rty's Avatar
What kind of Trq numbers do you think we will see with this thing? Will that decrease with this sized turbo? I personally like to have more trq than HP.
Old Dec 9, 2010 | 03:34 AM
  #402
Dart_SI's Avatar
im opposate. id rather have more hp than torque, and just raise the redline a bit. i personally think a car with 400whp and 350 tq shifting at 8k will pull a car with 400whp and 450 tq shifting at 6.5k with the same gearing. plus its easier on the clutch and drivetrain.
Old Dec 9, 2010 | 04:35 AM
  #403
40rty's Avatar
Impulse Engines : Performance : More Average Torque
Do the math that my link shows you with your current dyno numbers and tell me what you get.
And I would guess that in your example the 400whp 450wtrq would win as that Trq would help accelerate you faster from a dig. Sorry don't do rolls.
Old Dec 14, 2010 | 09:48 AM
  #404
Stamina's Avatar
bump for updates
Old Dec 14, 2010 | 12:02 PM
  #405
40rty's Avatar
woke up this morning wondering the same thing^^^^
Old Dec 14, 2010 | 12:10 PM
  #406
Stamina's Avatar
Well, here's something to hold us over that BNR sent, courtesy of Cubaniche:
Stage 1 (K04-GT2860)
Stage2 (K04-GT2871)
Old Dec 14, 2010 | 12:42 PM
  #407
09BlueBaltSS's Avatar
Those graphs look exactly like the regular gt28 graphs that can be found floating around. Idk if that is the exact graph for this combo. I was expecting a little loss in efficiency. If this thing can flow 45lbs/min ill be happy
Old Dec 14, 2010 | 12:51 PM
  #408
cubaniche's Avatar
Thats the same thought Stamina and I had. I asked BNR for the graphs directly and thats what he sent. Seems to me hes pretty confident that his mods will flow almost the same...???
Old Dec 14, 2010 | 03:37 PM
  #409
RoadconeTuning's Avatar
how does our K04 hotside compare to a 2871?
Old Dec 14, 2010 | 04:15 PM
  #410
Stamina's Avatar
It doesn't...
But in all seriousness, here's the info...
Old Dec 14, 2010 | 05:34 PM
  #411
wow, i'll be surprised if the 2871 makes over 400
Old Dec 14, 2010 | 06:15 PM
  #412
Stamina's Avatar
You're saying that based on the turbine?
Old Dec 15, 2010 | 08:56 AM
  #413
I'd love to be wrong here but, I just dont think its going to work as well as everyone thinks... Full-Race has a T3-T67 hybrid that is okay but my buddy swapped to a GT4088 which has a few mm smaller compressor and picked up like 50hp on pump gas lol
Old Dec 15, 2010 | 10:24 AM
  #414
Stamina's Avatar
I pulled up the turbine specs. Were you wanting the compressor wheel specs? I'm not sure I follow what you mean as far as just looking at the turbine end of the turbo.
Here are the compressor specs:
Old Dec 15, 2010 | 10:55 AM
  #415
CudaJoe's Avatar
the 2871 will make over 400 horsepower... the 2860 will make 370hp
Old Dec 15, 2010 | 11:33 AM
  #416
elecblue06's Avatar
i wouldn't see our exhaust side killing flow that much.. and a 2871 turbo on the stock manifold has already made 400+ whp
Old Dec 15, 2010 | 11:37 AM
  #417
JacBlackSS/TC's Avatar
i think low 400s are a respect amount of power for a pretty much stock turbo
Old Dec 15, 2010 | 11:38 AM
  #418
Stamina's Avatar
Well, the thing is that he has also machined the exhaust side, so it no longer has the stock specs/dimensions and is basically an unknown now.
Old Dec 15, 2010 | 11:41 AM
  #419
well i can't wait for Joe to get his so we can get it on the dyno
Old Dec 15, 2010 | 12:24 PM
  #420
Exactly. People are making assumptions off of what a regular 2871r would make.
Old Dec 15, 2010 | 12:51 PM
  #421
correct me if im wrong but is this not just a wheel/cover swap on the compressor side? I was saying stock K04 turbine w/ a 2871 compressor just doesnt seem like it would work all that well... bigger heavier wheel trying to grab more air and keeping the same force on the turbine when the 2871 clearly has a bigger area for the exhaust to apply its force... now if hes stuffing a 2871 into a stock turbine HOUSING then this could be veeerrryyy interesting
Old Dec 15, 2010 | 01:00 PM
  #422
cubaniche's Avatar
Its a full gt28 conversion. Both wheels are replaced and the housing on both sides are machined accordingly to fit. This is why I guess he feels comfortable using the stock garrett gt28 flow maps, because it will flow very similarly. Its not JUST a big wheel upgrade. Again, machined K04 housing with full gt2860 and gt2871 internals.
Old Dec 15, 2010 | 01:04 PM
  #423
On the 2871 the compressor cover is the actual 2871 cover. The only machining done was for the shaft and turbine to fit the K04 turbine housing/center. Right?
  #424
that will work pretty phenomenally then...
Old Dec 15, 2010 | 01:43 PM
  #425
cubaniche's Avatar
Correct. The 2871 has the upgraded housing. I was trying to minimilize what I was trying to say, sorry. I would love the 2871 but the upgraded housing eliminates the BPV and thus would require a BOV somewhere in the system and, me personally, I dont wanna mess with all that..lol...I think the 2860 should get us to at least 350 conservatively and 370 pushing it. Im happy with that, plus maybe the ZZP cams if they ever get released
