Bnr k04-gt28
Old Feb 6, 2011 | 09:45 PM
  #976
Mike_peperni's Avatar
Nice!
Old Feb 6, 2011 | 11:10 PM
  #977
iboost's Avatar
Good to hear.
Old Feb 7, 2011 | 12:58 AM
  #978
tglems's Avatar
Yeah green bay!!!!! World champions!!!!!!!!!
Old Feb 7, 2011 | 10:29 AM
  #979
cubaniche's Avatar
Nice progress HHRSouth! Man the weld on the extended tip is a thing of beauty! lol
Old Feb 7, 2011 | 10:44 AM
  #980
iboost's Avatar
God I want one of these so bad. So you say the install wasn't bad at all huh? What all did you have to do for it? Jack the car up and what not?
Old Feb 7, 2011 | 10:56 AM
  #981
BYT*SS*TURBO's Avatar
I have to say the biggest PITA is removing the stupid breather lines. The one on the Valve cover is a real ***** lol..
Old Feb 7, 2011 | 11:00 AM
  #982
Sweetsandman's Avatar
Wheels or Turbo...wheels or Turbo...this is going to be a tough decision with what to go with first.
Old Feb 7, 2011 | 11:10 AM
  #983
That flange unbolts from the turbo with 1 10mm bolt lol. Thats funny they sent the whole line :p
Old Feb 7, 2011 | 01:02 PM
  #984
PrincessTurbo's Avatar
Can you see your wheels while your boosting @ 400 Wheel .. Didnt think so .
LOL , I just made your decision
Old Feb 7, 2011 | 01:08 PM
  #985
iboost's Avatar
Originally Posted by HHRSSouth
Your definetly going to have some wrench time taking it off. Plan everything out, heck it doesn't even hurt to write it down on a piece of paper
Something I always use for doing work the first time is take pictures with a digital camera, so you can go back and look for reference if you forget something.
It will take you half the time to put everything back on. It did me and I even had to tweak lines to work.
The K04-GT2860 I bet I could swap out in one day with the factory K04, since its a pure bolt on. No adjustments, line tweaking or making sure the turbo is clocked right for the UICP.
Good to know. I'll prolly be doing this after I get my car in Hawaii
Old Feb 7, 2011 | 01:55 PM
  #986
Turbo'dSS's Avatar
LOL!!! this is so true!
It is actually, its a machined piece, not just a piece of aluminum pipe welded on
I watched Brian weld it on my turbo, then go bead blast the compressor cover with the new tip on it, then re-assemble the whole turbo.
So did he just do this for you or are all of the 2871's now coming like this?
Old Feb 7, 2011 | 01:57 PM
  #987
hunter19707's Avatar
Yep, I ended up bending the flare out all the way around even more, to access the tabs. But I was looking at the part as I won't need it anymore with the K04-GT2871.
If someone is using the 2860, be extra careful and do not break that piece you need it.
I saw some of the cores Brian had, there where some with that line attached to the turbo and the nipple of the valve cover broke off inside the other end lol.
This would make me nervous, I tend to be a little impatient.
Old Feb 7, 2011 | 03:38 PM
  #988
Extremely valid point...Although, nobody can see the GT28 under the hood while it sits in the partking lot...but your thoughts have definitely made an impact on where my Visa will ring up
Old Feb 7, 2011 | 04:54 PM
  #989
mongorat427's Avatar
I got a tool for it at Advance for $10 bucks. Works perfect
Old Feb 7, 2011 | 04:58 PM
  #990
Which tool, knowing me, I'd end up breaking the damn thing.
Old Feb 7, 2011 | 05:00 PM
  #991
iboost's Avatar
I don't think that tool works very well on the line that goes from the valve cover to the turbo. I couldn't get it off nicely when I replaced my valve cover
Old Feb 7, 2011 | 07:49 PM
  #992
pbass's Avatar
Go to the Advance web site and read the customer reviews. The ratings are very different for different tools.
I bought one at my local Harbor Freight (someone on the forums recommended it), but I haven't used it yet.
Old Feb 8, 2011 | 12:17 AM
  #993
iboost's Avatar
what kinda torque numbers is this turbo supposed to put down?
Old Feb 9, 2011 | 07:45 PM
  #994
turbo_chevy_cobalt's Avatar
If it is like my old kit i would say at least 400 or a little more depends on the tune and other things come into play. I just got a new tune update on 26psi and wow it moves. Will try to get video of tonight if i can find a race.
Old Feb 9, 2011 | 09:57 PM
  #995
Or just take one of the speedometer, just to give an idea how quick it is
Old Feb 10, 2011 | 12:00 AM
  #996
T-Man's Avatar
Man.... 2860 or clutch.... 2860 or clutch....
Bleh...
Old Feb 10, 2011 | 12:19 AM
  #997
lol from a dig or roll?
Old Feb 10, 2011 | 01:08 AM
  #998
Bleh...
May need the clutch to handle the 2860.
Old Feb 10, 2011 | 01:13 AM
  #999
elecblue06's Avatar
both
Old Feb 10, 2011 | 01:29 AM
  #1000
or just a dig to around 140
