Boost Problem
Old Jun 20, 2015 | 08:12 PM
isaiah14212's Avatar
Boost Problem
Alright so I finally got my 2009 cobalt ss with 6758 and full bolt ons tuned by zzp LNF PCM and let me say it runs amazing now. I also purchased GMS1 sensors which fixed my sensor check engine light. Now the car runs great and pulls very hard but like before I am still only pushing 10lbs of boost. I thought because the bad sensor or tune was why it was only making 10psi but the new PCM i got says its tuned for 22psi. I emailed them about the problem thinking it might be the wastegate but they told me the wastegate already comes pre-loaded. So if its not the wastegate what else could it be?
Old Jun 20, 2015 | 08:17 PM
Check the pre-load, and check for boost leaks
Old Jun 20, 2015 | 08:19 PM
Have you checked for boost leaks?
Old Jun 20, 2015 | 10:28 PM
No I haven't. I'd figured if i had a boost leak I would get a code. As for pre-load how do i check that on the efr 6758. I was told it has an interal wastegate so is this still possible? also where should i look for boost leaks?
Old Jun 21, 2015 | 01:42 AM
brycerice13's Avatar
Did you get it tuned after you changed the sensors? You must change the calibration for those sensors once you change them to the 3 bar map sensors.
Old Jun 21, 2015 | 03:04 AM
Yes i ordered the tune with it being tuned for those sensors
Old Jun 28, 2015 | 09:55 AM
Okay i am pretty sure i found the boost leak. There is no vacuum line going to the by pass valve on the turbo. The only problem is i cannot find a vacuum line that isn't connected to anything. Am i suppose to tap into another line in order to run it to my bpv? Here are some pictures and it would be nice if someone could tell me which vacuum line is suppose to go to the bpv. thank you.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
