bpv issue?
Old Dec 19, 2014 | 02:22 AM
LNFwagonSS's Avatar
Originally Posted by kzak104
If bypassing the solenoid helps then you probably have a faulty solenoid.
Old Dec 19, 2014 | 11:22 AM
roadrunner132's Avatar
I doubt it's a bad bpv solenoid. It only happens when it's cold right after starting it the first time for the day. I seems more like the bpv is just sticking then I boost and it breaks it free. I don't know. I am running the yellow spring. I'm gonna go put the green spring in and see if that helps.
Old Dec 19, 2014 | 02:29 PM
Shanedude's Avatar
Originally Posted by LNFwagonSS
If you don't see "engine power reduced" on the driver display then it's not limp mode..
It doesn't always say engine power reduced. Done my fair share of limp mode :P
Old Dec 19, 2014 | 03:19 PM
LNFwagonSS's Avatar
That just doesn't make sense to me. Why would it be called limp "mode" if it reduces power for one pull and not the next. How did you come to this conclusion?
Old Dec 19, 2014 | 03:38 PM
ATOMbomb's Avatar
I wonder if my evap purge solenoid is the reason it did that for me. Once it a while, while I'm just cruising. The car will feel like it jumps a little bit for a second. The boost gauge drops a bit while this happens. I've read a bunch of post saying that they changed their evap purge solenoids and it was fine.
Old Dec 19, 2014 | 03:39 PM
Shanedude's Avatar
Long early morning drives to work 90% in limp mode. No engine power reduced. After shift on the way back car runs flawlessly. Thank god those days are over. Didn't want to pass another car incase it put itself into limp mode randomly.
Old Dec 19, 2014 | 04:19 PM
blueLNFftw's Avatar
If it doesn't say it then the PCM didn't command it.
Something else was the problem.
Old Dec 21, 2014 | 02:04 PM
Shanedude's Avatar
Limp mode without the "pwr reduced" message appearing is 100% possible. Limp mode without a dash light appearing is 100% possible. Trust in cobalt.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
