Bypass valve issue?
Old Nov 30, 2012 | 12:40 AM
Sox-Fan's Avatar
Got Brakes?
I was thinking that he might. I'll check the solenoid and the lines tomorrow morning. I can't get into the shop this weekend so if the weather is good I'll pop the Forge off. Disassemble, inspect, and clean it then put it back on. If I don't find anything I'll try Mongo and see if he has a stocker I can buy from him and see where that takes me. I'm making plenty of boost and it holds it - right up to about 5,500 rpm. I think you guys are right. Gotta be something up with that valve.
Thank you guys for the help. I'll keep you updated.
Old Nov 30, 2012 | 09:22 AM
Sox-Fan's Avatar
Got Brakes?
Solenoid is plugged in securely. Vacuum line secure, clear, unkinked. Did a slow gradual roll up with no boost up to 6,500 with no boost and it was clean and smooth. I think I'm going to have to pull that Forge off this weekend and inspect it. Supposed to be great weather this weekend.
Old Nov 30, 2012 | 08:46 PM
Frogstofall's Avatar
Gotta be that Forge...
Old Nov 30, 2012 | 09:10 PM
Sox-Fan's Avatar
Got Brakes?
Can't be anything else, can it? I mean I have inspected everything except that and the lower map which is awfully close to the fan with this tuboxs pipe. I'll be giving that a good inspection too, just to be complete and thorough.
Old Nov 30, 2012 | 11:25 PM
Wangspeed's Avatar
It's not the Forge. What happened when you slowly crept to 5500 w/o full boost? I suspect it's a tune or sensor issue.
Old Nov 30, 2012 | 11:36 PM
Sox-Fan's Avatar
Got Brakes?
No issue. I slowly ran it right up to over 6k. Smooth. Repeated it, the second time doing it hard enough to require boost, same issue.
The tune hasn't changed at all. I don't even have a cable to do so. Could it be something that the weather change has caused. Maybe but I think Term knows how way around a tune pretty well.
The Forge was R+R within the last month so in my mind that demand a double check of my work there. The lower 3bar sensor is very very close to the fan shroud. I was planning to get a new lower pipe because I've been concerned about that. I'll give it a thorough check tomorrow. I haven't had time and daylight to really inspect everything under the hood but this weekend I will for sure.
You're using synthetic grease for the bpv, aren't you?
Old Dec 1, 2012 | 12:00 AM
Wangspeed's Avatar
It almost sounds like either the Pressure Boost Limit isn't high enough, or one of the Overboost/Underboost tables wasn't tweaked. I asked if you had it last winter because now that the air is colder, you will likely make more boost faster.
Ask Term to take a look. This is something that is difficult to find without logs. Sticking by tune or sensor issue.
Old Dec 1, 2012 | 12:06 AM
Sox-Fan's Avatar
Got Brakes?
Ok, I'll look at everything mechanical that I can this weekend. 2 weeks from now I'll be back in Florida and I'll try to set something up with him to run some logging.
Thank you.
Old Dec 1, 2012 | 08:04 AM
Wangspeed's Avatar
In the meantime, clean your MAF, and 2 MAP sensors with MAF cleaner. Doubt this will fix it though.
Old Dec 1, 2012 | 08:11 AM
Sox-Fan's Avatar
Got Brakes?
Cleaned the MAF last weekend. I'll get the MAPs this weekend.
New tires this morning!
Old Dec 1, 2012 | 06:05 PM
  #36
LNFwagonSS's Avatar
Originally Posted by Sox-Fan
Thinking about this some more.. The vacuum line to the Forge: If I were to plug it would I expect the forge to always bypass or never bypass? I'm not positive about how it works. I winder though if plugging that hose would be any kind of a test at all?
I believe the vac line to the BPV applies pressure to the BPV while boosting.
Also, if you have a forge valve with the angled 90 degree nipple, it is threaded and can come loose causing a leak. Just a thought.
Old Dec 1, 2012 | 10:47 PM
  #37
Powell Race Parts's Avatar
what color is ur HHR? looks nice in the sig
Old Dec 2, 2012 | 11:40 AM
  #38
Sox-Fan's Avatar
Got Brakes?
Well, at this juncture I'm thinking that I am my own worst enemy. Remember that I posted somewhere long the in here that I'd serviced the Forge recently? I guess that was a misnomer. OVER serviced is more like it.
So much grease. What was I thinking?
I cleaned the MAPs and then took off the K+N and the Forge.
When I removed the Forge I found the piston on the unit was stuck UP. I had to tap it with my finger a few times for the spring to be able to push it back down. This can't be good, huh? So, I cleaned it again thoroughly and just put a small film of grease inside the barrel of the housing where the O-rings ride, making sure not to get any on the end. Piston runs up and down niiiiiice and smooth now. Put it all together and I'm about to go for a spin to test it.
Wanna bet the car runs better now?
I also noticed the slightest film of oil inside the end of the K+N where it goes into the turbo coupler. Not enough to get upset over, but enough to be concerned. John's PCV drainback setup was already on my TODO list. It just got bounced up a spot or two.
I'll post results after I run for coffee and give the car a bath and some wax.
Old Dec 2, 2012 | 01:14 PM
  #39
LNFwagonSS's Avatar
Thank you. Its silver ice metallic. The lighting make it look much better in the pic.
Old Dec 3, 2012 | 09:24 AM
  #40
Aleksey's Avatar
Was about to post that it's definitely not the Forge BPV unless you did something wrong. Seems like a user error to me but keep us updated on what your findings are.
Old Dec 3, 2012 | 07:41 PM
  #41
Update? Sounds like it was the Forge. Whether you caused it or not...
Old Dec 3, 2012 | 07:48 PM
  #42
Sox-Fan's Avatar
Got Brakes?
I was just typing out a followup!
So, car pulls to the top with boost now. Holds it all the way up, no problem.
But ... Instead of the normal rock steady 25 lbs it only pulls 18. And tons of K.R. This car never pulled timing before but geez. Once it's up to temp just letting out the clutch it pulls back 2.7. Goose the throttle a little in neutral and .7.
Never experienced that before. I'm guessing boost leak but that's a total guess based no nothing more than thinking that I had the MAPS, MAF, intake and Forge off the car.
Old Dec 3, 2012 | 08:15 PM
  #43
LNFwagonSS's Avatar
Sound like you should have pending codes. Go drive the car and try to recreate the problem several times until MIL lights up. Scan codes. Report findings.
Old Dec 3, 2012 | 08:25 PM
  #44
Sox-Fan's Avatar
Got Brakes?
No codes. Been driving it for 2 days. A few hard pulls but mostly just driving it. Stop and go kind of stuff watching the K.R. Driving highway or steady speed doesn't pull timing. It's letting out the clutch from a stop with light throttle that does it. hard on the throttle doesn't retard at all.
Old Dec 3, 2012 | 08:39 PM
  #45
tune. talk to term. these cars in colder weather pull like a ****, and with winter rvp gas its not good at all/at all. My wntrbtr2 pulls like a John Force funny car these cold mornings, i love it, but the fact is stock tunes are fail safe. Edgy tunes are more problematical. So drive easy and get onto term toot sweet.
PS the pcv will fix that oil but pay attention because my guess is with detonation you are getting a lot more blow by and that is not good. You need undamaged piston rings and ring lands.
Old Dec 3, 2012 | 08:41 PM
  #46
Sox-Fan's Avatar
Got Brakes?
I'm heading down there the 15th. I'll try to book an appointment with him. This weekend I'm going to take everything apart again, just to satisfy my mind that I left nothing leaking.
Old Dec 3, 2012 | 08:48 PM
  #47
did I say I am a GMS1 fanboi?
if you get my drift....
Old Dec 3, 2012 | 08:49 PM
  #48
Sox-Fan's Avatar
Got Brakes?
Eh, GMS1, term 2, Trifecta. Had em all, never had an issue with them till I decided it was time to service the Forge. I've nobody else to blame but me.
Old Dec 3, 2012 | 08:57 PM
  #49
^^^lol. an honest man. Didyou buy a stock one from Mongo? I hate those forges...
Old Dec 3, 2012 | 09:02 PM
  #50
Sox-Fan's Avatar
Got Brakes?
no, I was planning on it but I'm getting to where things slip my mind rather easily. I will now. It'll tell you though, it's difficult for me to go back to a diaphragm after all those extremely cold winter days replacing the transfer pump diaphragms on my B model cat. Freezing cold blowing snow and diesel fuel all over you. Kinda traumatizes you a little. That stuff sticks with you forever.
