CEL=Evap system
Old Aug 9, 2009 | 11:19 PM
RYRO14's Avatar
CEL=Evap system
Threw a CEL and called onstar and they said it was my evap system malfunction, what does that mean?
Old Aug 10, 2009 | 12:16 AM
Gettinausernamesucks's Avatar
If you don't get the fuel cap tight it will drop an evap code. The system runs a pressure test on your fuel tank and purge lines everyting you drive the car. If the pressure test on the fuel tank fails it will set an evap code. A loose fuel cap will also cause it and is the most common reason.
Old Aug 10, 2009 | 04:46 PM
Terminator2's Avatar
Could be loose fitting on the purge canister. Or a leaking or stuck purge solenoid (on intake manifold). Mine used togive that CEL. It ended up being that the purge cannister had fitting that was loose. I fixed it myself.
Old Aug 10, 2009 | 05:01 PM
RYRO14's Avatar
Yea I just took it to the dealer they said it was something about a canister or something and purge solenoid? Whatever it is warranty
Old Aug 10, 2009 | 06:13 PM
KimiKiri's Avatar
I had this same problem. Just make sure your gas cap is on tight and it will go away after a few weeks. You can also go to the dealer to have them reset it if you like. I did not do this because Im tuned...
Old Aug 12, 2009 | 12:43 PM
rckrz6's Avatar
i was on it hard and shifted into 2nd on a wet ground with traction control on.. It threw me a service cel code real quick then went away
Old Aug 12, 2009 | 12:53 PM
RYRO14's Avatar
I guarantee it was a misfire. Most LNFs have had a misfire in their day
Old Aug 12, 2009 | 01:12 PM
I called it.
That is what I thought it was.
Last edited by Terminator2; Aug 12, 2009 at 01:12 PM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
