Chain tensioner issue
Old Sep 24, 2018 | 03:57 PM
cobaltssdude420's Avatar
I put a new head on and decided to do the timing chain as well a few weeks ago. Now I'm getting an s257 so I decided to do springs and cams. I took apart the tensioner and reset it but when I tighten it in the head, it doesn't tension the chain...grabbing a new one but any thoughts? I've reset the tensioner a few times and no luck
Old Sep 24, 2018 | 04:48 PM
Kolt's Avatar
When you reset the tensioner you have to hit it after installing it to get it to fully release.
Old Sep 25, 2018 | 08:42 AM
I've already tried that. Must not be hitting it hard enough lol
Old Sep 25, 2018 | 11:32 AM
exninja's Avatar
If you haven't, look up online exactly where and how to hit it. It's a firm whack, but if you do it right it's not bad and it's obvious it worked.
Old Sep 25, 2018 | 01:02 PM
Well I'm guessing the head of the bolt is where it needs to be hit because it's got the raised end
Old Sep 25, 2018 | 01:07 PM
Kolt's Avatar
It needs to be hit right in line where the tensioner presses against the guide. Gm doesn't give a picture on where, just a description where it needs to be struck and it has to collapse more than 2mm before it releases.
Old Sep 25, 2018 | 01:11 PM
It would've been nice if my Haynes manual included this information ffs.
Old Sep 25, 2018 | 01:21 PM
Found it, guide needs to be struck
Old Sep 25, 2018 | 01:22 PM
Kolt's Avatar
Surprised it doesn't. You are resetting it correctly right? The inner shaft gets pressed down and you turn it to lock it in to the notches.
Old Sep 25, 2018 | 01:26 PM
Of course man. I've had it apart a few times now. Attachment 62105
Attachment 62106
Old Sep 25, 2018 | 01:27 PM
Why can't I post a picture in here anymore?
Old Sep 25, 2018 | 01:41 PM
Kolt's Avatar
should be able to upload from device unless its a unsupported format or too large file size
SKY888
Aug 8, 2014 10:35 AM
CanadianCobalt
Mar 1, 2011 09:21 PM
shutzero
Feb 1, 2009 06:47 PM
2K5SS/SC?
Aug 19, 2006 09:06 PM
