Charge pipe recall - Are they supposed to change the pipe itself?
Old Oct 5, 2010 | 10:26 PM
lewis_trash's Avatar
I got my car in for the power steering recall and charge pipe. I specifically asked the tech if he got the charge pipe recall done, he said yessss sir.
Well I got back home and checked that pipe --> It's the same pipe I had before.
Is this recall just some part they install at one end of the pipe or is it supposed to be a whole new pipe??
Thanks guys
Old Oct 6, 2010 | 12:47 AM
importkiller's Avatar
no, it is simply a replacement of the retaining system that holds the charge pipe down.
Old Oct 6, 2010 | 10:57 AM
SSlobalt's Avatar
It's a bolt and a clip.
Old Oct 6, 2010 | 11:13 AM
redninja6r's Avatar
Hell I still haven't got the steering pump done yet. No letter. I didn't know there was a charge pipe recall either!
Old Oct 6, 2010 | 12:46 PM
09CobaltSS1's Avatar
Thanks guys
unless the pipe is damaged, they will only replace the bolt and clip that retains the charge piping to the mount on the engine to elliminate the chance of the pipe coming loose from the mount.
The steering system in the cobalts is electric, not hydraulic, so there is no pump. They replace the electrical steering motor for the recall..
Old Oct 6, 2010 | 06:56 PM
SSlobalt's Avatar
No pump, just an electric motor.
Old Oct 6, 2010 | 06:57 PM
is there an echo in here?
Old Oct 6, 2010 | 08:23 PM
Malaclypse's Avatar
You don't need a letter to get the recall done. Call your local dealer and ask them about the recall. They'll ask for the last 8 of your VIN to see if you're eligible. If you are, they'll ask you to come in.
That easy.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
