Check Engine Light Is on. Nothing is going wrong with the car?
Old Nov 6, 2010 | 09:52 PM
Boxing Fan's Avatar
I drove the car a little earlier today. I didn't notice a code, then drove again tonight, and when I turned the car on it was on.
I should note I NLS way to much.
The car shows no signs of problems, all the hose look connected and good, etc.
I read on here it may just be a misfire from NLS'ing and that it should go away? If not is there any way to check the code without a OBDII scanner?
Old Nov 6, 2010 | 09:53 PM
sporttintturbo's Avatar
hptuners, onstar can do it too
Old Nov 6, 2010 | 09:55 PM
Boxing Fan's Avatar
I know there was a trick for most if not all of the 90's cars to check what the code is without that fancy scanner stuff.
Old Nov 6, 2010 | 10:01 PM
im not sure about that unless its a cat C16 engine haha. why dont u want to scan it. u can ghetto reset it. unhook your battery for like 5 minutes, if its not a reoccuring code it will go away. but u gotta reset your clock, radio stations, i had it **** my tune up before. so just some warnings
Old Nov 6, 2010 | 10:16 PM
Boxing Fan's Avatar
Ya thanks. Totally slipped my mind to restart it with the battery.
Old Nov 6, 2010 | 10:32 PM
not a problem, glad i could help!
Meadowvalien
Aug 17, 2017 06:32 PM
vjoel2011
Oct 2, 2015 12:11 PM
yellowsupercharged06
Sep 17, 2015 04:40 PM
jthwjde
Sep 7, 2015 09:24 AM
Fearedbynone
Sep 4, 2015 10:24 AM
