Checking for boost leaks
Old May 17, 2011 | 05:27 PM
rckrz6's Avatar
I just installed my hot side piping and wondering if there is a good way to determine if there are boost leaks besides pressurizing the system. how tight is to tight for the clamps?
Old May 18, 2011 | 01:59 PM
SSlobalt's Avatar
Pressurizing is the only way to reliably check for leaks.
Old May 18, 2011 | 03:08 PM
YelloEye's Avatar
This.
No other way to test the system under pressure.
Old May 18, 2011 | 08:15 PM
seeyaass's Avatar
I always thought about pressuriZing the system with some sort of smoke screen or something so you can see if there was a boost leak cause smoke will come out lol. Just a thought.
Old May 18, 2011 | 08:51 PM
TommyP's Avatar
AWD > FWD
I would imagine you could also do the same thing you do with a leaking tire, put soapy water on all the connections, watch for bubbles.
Old May 18, 2011 | 08:56 PM
SSlobalt's Avatar
Yup. That's what I do to check for the smaller leaks.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
