chevy dealer wont install kit
Old 07-16-2010, 05:32 PM
gangstarplaya72's Avatar
i bought the gm stage kit and the dealer said they wont install it for me...i live in suffolk county long island anybody kno a dealer around here that does the install?
Old 07-16-2010, 05:34 PM
northvibe's Avatar
why? they arent gmpp certified or you didnt buy it there? Will they do just the flash? then you could install the sensors yourself and bring it in for the flash. Otherwise good luck! I think someone will speak up with a good place to take it.
Old 07-16-2010, 05:37 PM
i never asked the guy just said they dont do it>>>>and if it helps its roberts chevy in nassau that wont do the install the place i got my car from
Old 07-16-2010, 05:54 PM
SSlobalt's Avatar
Buncha ******.
Old 07-16-2010, 06:02 PM
Dart_SI's Avatar
gms1 install is stupid easy. the stealership is probably just a bunch of retards.
Old 07-16-2010, 06:09 PM
troyss's Avatar
What does the gms1 consist of. Like what parts are needed to install?
Old 07-16-2010, 06:29 PM
SSlobalt's Avatar
The OEM MAP and TMAP sensors have to be replaced, which means the pigtails have to be replaced, which means you have to cut the factory connectors off and solder in the new pigtails. There is also a boss on the TMAP sensor that has to be ground off to allow it to bolt to the coldside pipe correctly. There is a problem with the orientation of the TMAP sensor, though. The 2.5 bar OEM is at a 90-degree angle, and the 3.0 bar is a straight connection, which leads to problems with interference from the A/C compressor lines in one direction, and the fans in the other. Why they couldn't make a 90-degree 3.0 bar MAP sensor is beyond me.
Old 07-16-2010, 06:32 PM
09Balt's Avatar
I know what your goin through i asked if the dealer could put a turbo on my balt and they said they could but they didnt want to
Old 07-16-2010, 06:49 PM
O9cobaltSS's Avatar
they could but didnt want to LOLLL
Old 07-16-2010, 08:50 PM
northvibe's Avatar
well at least they said no, instead of half installing the kit then saying, **** we broke it.
Old 07-16-2010, 09:23 PM
Nighthawk243's Avatar
They either think you're talking about the SS/SC's stage kits (Which are a bitch to do the pulley swap on since most dealers don't have the necessary equipment to properly remove the stock pulley and press the new hub on), or they just don't feel comfortable with possibly screwing something up.
Call another dealer and see if they'll do it. I'd imagine Long Island has more than one dealer.
Old 07-16-2010, 09:39 PM
DavidW's Avatar
you never awnsered if you bought it from them or not
I believe only gmpp dealers are "allowed to install and sell it"
so look up gmpp dealers, theirs a list somewhere online
Old 07-16-2010, 09:56 PM
UnderPressure's Avatar
call Paul Conte In freeport.... there service manager is pretty good.... I would be surpised if they turned you down.... Ive been servicing my cars there for years..... Im on my 2nd cobalt and my mom services her HHR there.... Ive even brought my trans am in and they replaced a window motor for me......
Old 07-17-2010, 12:45 AM
Macgyver2484's Avatar
What is wrong with these dealerships? Do they just hire random people off the street that can’t cut some wires? I installed the sensors in less than 30 minutes. The directions were extremely easy to follow. It took my dealership over an hour just to flash the ECU….I mean, come on! I wish I could just rent the damn OBD tool and flash it myself too. Most of them brag that they have “ASE” certified techs...what a bunch of bull.
Old 07-17-2010, 01:00 AM
Axelthered05's Avatar
https://www.trifectaperformance.com/cia-order/ JK JK
Old 07-17-2010, 01:09 AM
ASE Certification means nothing anymore.
This was from a Chevy Dealer that was "ASE CERTIFIED" and they did this Maaco-job:
https://www.cobaltss.net/forums/show...ghlight=grille
Old 07-17-2010, 01:15 AM
Its sad when "ASE CERTIFIED" means crap. How are guna know if a place is guna F#$k up our cars or not when they can get away with crap like that ^^^
Old 07-17-2010, 10:54 AM
if i installed it my self and had the dealer just reflash the car would that work? would they be able to do that or does reflashing the car take a long time?
idc if i hae to drive to get this kit installed does anybody know any place in ny that installs the kits id even go to conneticut if i had 2
Last edited by gangstarplaya72; 07-17-2010 at 10:54 AM. Reason: Automerged Doublepost
Old 07-17-2010, 01:31 PM
DavidW's Avatar
did you not read my post ?
Sorry but that just makes me mad, i gave you information you need already and your still asking for it
if you search "gmpp dealers" in google the first result is their official gmpp dealer finder where you enter in your zip or you pick a city/state to find a gmpp dealer
Old 07-17-2010, 04:28 PM
yo im sorry dude i tottally missed that post when i replyed but i have since done that and found a dealer thanks
Old 07-17-2010, 07:32 PM
Ill do you one better
NESENGER 112 CHEVROLET
2096 RTE 112 MEDFORD AVE
MEDFORD , NY 11763 -0000
Phone: (631 ) 758-2200 Fax: (631 ) 758-3121
Ive already called the, they can get and install the GMS1 kits..... I dont see it being a problem if you have one already and just need an install.... now I have to get over there and order mine
Old 07-17-2010, 07:57 PM
DavidW's Avatar
if only you were 3 hours earlier : )
Old 07-18-2010, 05:04 PM
D-mac's Avatar
Does anyone know if the Performance Autowerks sensors look exactly like the ones that GM would use?
I have to swap my sensors and pcm back in for a warranty repair but would rather just have them flash the GM Stage 1 Flash on my factory computer for warranty purposes
Old 07-19-2010, 08:23 PM
Hugger1975's Avatar
this should be enough of a reason to convince you to go elsewhere OP.
https://www.cobaltss.net/forums/08-10-ss-turbocharged-general-discussion-152/soooo-pissed-so-only-certain-dealerships-can-mess-gms1-local-has-no-clue-221387/
Old 07-19-2010, 10:49 PM
Tomtwtwtw's Avatar
https://www.cobaltss.net/forums/08-10-ss-turbocharged-general-discussion-152/dealerships-will-install-stage-kit-194712/
Quick Reply: chevy dealer wont install kit
