Cobalt ss T/C exhaust popping after 5k?
Put a 3" MPX catback exhaust with a ZZP catted DP on my '09 T/C. Now when I floor it in second, after 5k my exhaust starts popping and wont reach redline as fast due to the popping. Also, it throws a CEL once it's starts popping. Any suggestions on what it might be? Or how to fix? Thanks.
lnf's run factory spark plugs period! change them about every 10k miles and with that amount of mods get a tune NOW. not only will your car run like it's supposed to but you'll gain around 70whp and about 100wtq.
Running rich at WOT due to power enrich + hot exhaust temps = boom in exhaust
Do you know what the code is? If you don't there is no reason not to own this:
and download Torque or another OBD scanner app on the smartphone I'm assuming you have
Update:
put the stock plugs back in. Runs fine, cleared the code and hasn't popped back up yet. Got on it a little bit and no popping. But it's raining where I am and I wasn't tryin to die haha. Thanks guys
try seafoaming the car....
also, check plugs see what they look like...
also get a tune. if budget is your problem. get a budget trifecta tune.
your problem sounds like detonation which is the worst thing possible for our cars... but very common as well...
i don't think just putting an exhaust on will cause this problem..
I had about 9k on my car with a trifecta tune on 93, i was beating on it for about 30 minutes straight in 95 degree weather and right after 5k it did the same thing. As soon as i let it cool down i took it back out and it drove perfect.... i think it has something to do with the exhaust temps, or maybe IAT's and the car retarding the timing... i never threw a code though
